1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/vtk/hierarchy/Prism" TYPE FILE RENAME "vtkPrismServerManager-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/vtk/hierarchy/Prism/vtkPrismServerManager-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
50  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so" AND
51  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so")
52  file(RPATH_CHECK
53  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so"
54  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
55  endif()
56  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so")
57  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so" AND
58  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so")
59  file(RPATH_CHANGE
60  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so"
61  OLD_RPATH "\$ORIGIN/../../../:/usr/lib64/openmpi/lib::::::::"
62  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
63  if(CMAKE_INSTALL_DO_STRIP)
64  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so")
65  endif()
66  endif()
67 endif()
68
69 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
70 endif()
71
72 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
73 endif()
74
75 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
76  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins" TYPE FILE FILES
77  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismIsSimulationDataDomain.h"
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismTableArraysDomain.h"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismThresholdRangeDomain.h"
80  )
81 endif()
82
83 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
84  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager/vtkPrismServerManagerModule.h")
85 endif()
86
87 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
88  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager/vtkPrismServerManager.spdx")
89 endif()
90
