Prism-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7  message(FATAL_ERROR "CMake >= 2.8.12 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.12...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS Prism::vtkPrismFilters Prism::vtkPrismViews Prism::vtkPrismServerManager Prism::vtkPrismReaders)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target Prism::vtkPrismFilters
59 add_library(Prism::vtkPrismFilters SHARED IMPORTED)
60
61 set_target_properties(Prism::vtkPrismFilters PROPERTIES
62  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
63 )
64
65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
66  target_sources(Prism::vtkPrismFilters
67  INTERFACE
68  FILE_SET "vtk_module_templates"
69  TYPE "HEADERS"
70  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
71  FILES
72  INTERFACE
73  FILE_SET "vtk_module_headers"
74  TYPE "HEADERS"
75  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
76  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismGeometryConverter.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkSimulationPointCloudFilter.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkSimulationToPrismFilter.h"
77  INTERFACE
78  FILE_SET "vtk_module_nowrap_headers"
79  TYPE "HEADERS"
80  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
81  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismFiltersModule.h"
82  )
83 else()
84  set_property(TARGET Prism::vtkPrismFilters
85  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
86  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
87  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
88  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
89  )
90 endif()
91
92 # Create imported target Prism::vtkPrismViews
93 add_library(Prism::vtkPrismViews SHARED IMPORTED)
94
95 set_target_properties(Prism::vtkPrismViews PROPERTIES
96  INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::CommonExecutionModel;VTK::PythonUsed"
97 )
98
99 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
100  target_sources(Prism::vtkPrismViews
101  INTERFACE
102  FILE_SET "vtk_module_templates"
103  TYPE "HEADERS"
104  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
105  FILES
106  INTERFACE
107  FILE_SET "vtk_module_headers"
108  TYPE "HEADERS"
109  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
110  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismGeometryRepresentation.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismGeometryRepresentationWithFaces.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismSelectionRepresentation.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismView.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkSMPrismViewProxy.h"
111  INTERFACE
112  FILE_SET "vtk_module_nowrap_headers"
113  TYPE "HEADERS"
114  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
115  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismViewsModule.h"
116  )
117 else()
118  set_property(TARGET Prism::vtkPrismViews
119  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
120  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
121  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
122  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
123  )
124 endif()
125
126 # Create imported target Prism::vtkPrismServerManager
127 add_library(Prism::vtkPrismServerManager SHARED IMPORTED)
128
129 set_target_properties(Prism::vtkPrismServerManager PROPERTIES
130  INTERFACE_LINK_LIBRARIES "ParaView::RemotingServerManager;VTK::CommonExecutionModel;VTK::PythonUsed"
131 )
132
133 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
134  target_sources(Prism::vtkPrismServerManager
135  INTERFACE
136  FILE_SET "vtk_module_templates"
137  TYPE "HEADERS"
138  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
139  FILES
140  INTERFACE
141  FILE_SET "vtk_module_headers"
142  TYPE "HEADERS"
143  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
144  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkSMPrismIsSimulationDataDomain.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkSMPrismTableArraysDomain.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkSMPrismThresholdRangeDomain.h"
145  INTERFACE
146  FILE_SET "vtk_module_nowrap_headers"
147  TYPE "HEADERS"
148  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
149  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismServerManagerModule.h"
150  )
151 else()
152  set_property(TARGET Prism::vtkPrismServerManager
153  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
154  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
155  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
156  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
157  )
158 endif()
159
160 # Create imported target Prism::vtkPrismReaders
161 add_library(Prism::vtkPrismReaders SHARED IMPORTED)
162
163 set_target_properties(Prism::vtkPrismReaders PROPERTIES
164  INTERFACE_LINK_LIBRARIES "ParaView::VTKExtensionsIOCore;Prism::vtkPrismServerManager;VTK::CommonExecutionModel;VTK::PythonUsed"
165 )
166
167 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
168  target_sources(Prism::vtkPrismReaders
169  INTERFACE
170  FILE_SET "vtk_module_templates"
171  TYPE "HEADERS"
172  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
173  FILES
174  INTERFACE
175  FILE_SET "vtk_module_headers"
176  TYPE "HEADERS"
177  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
178  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismSESAMEFileSeriesReader.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismSESAMEReader.h"
179  INTERFACE
180  FILE_SET "vtk_module_nowrap_headers"
181  TYPE "HEADERS"
182  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
183  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPrismReadersModule.h"
184  )
185 else()
186  set_property(TARGET Prism::vtkPrismReaders
187  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
188  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
189  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
190  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
191  )
192 endif()
193
194 # Load information for each installed configuration.
195 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/Prism-targets-*.cmake")
196 foreach(_cmake_config_file IN LISTS _cmake_config_files)
197  include("${_cmake_config_file}")
198 endforeach()
199 unset(_cmake_config_file)
200 unset(_cmake_config_files)
201
202 # Cleanup temporary variables.
203 set(_IMPORT_PREFIX)
204
205 # Loop over all imported files and verify that they actually exist
206 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
207  if(CMAKE_VERSION VERSION_LESS "3.28"
208  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
209  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
210  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
211  if(NOT EXISTS "${_cmake_file}")
212  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
213  \"${_cmake_file}\"
214 but this file does not exist. Possible reasons include:
215 * The file was deleted, renamed, or moved to another location.
216 * An install or uninstall procedure did not complete successfully.
217 * The installation package was faulty and contained
218  \"${CMAKE_CURRENT_LIST_FILE}\"
219 but not all the files it references.
220 ")
221  endif()
222  endforeach()
223  endif()
224  unset(_cmake_file)
225  unset("_cmake_import_check_files_for_${_cmake_target}")
226 endforeach()
227 unset(_cmake_target)
228 unset(_cmake_import_check_targets)
229
230 # Make sure the targets which have been exported in some other
231 # export set exist.
232 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
233 foreach(_target "VTK::CommonExecutionModel" "ParaView::RemotingViews" "VTK::PythonUsed" "ParaView::RemotingServerManager" "ParaView::VTKExtensionsIOCore" )
234  if(NOT TARGET "${_target}" )
235  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
236  endif()
237 endforeach()
238
239 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
240  if(CMAKE_FIND_PACKAGE_NAME)
241  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
242  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
243  else()
244  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
245  endif()
246 endif()
247 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
248
249 # Commands beyond this point should not need to know the version.
250 set(CMAKE_IMPORT_FILE_VERSION)
251 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
