3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7 message(FATAL_ERROR "CMake >= 2.8.12 required")
10 cmake_policy(
VERSION 2.8.12...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS Prism::vtkPrismFilters Prism::vtkPrismViews Prism::vtkPrismServerManager Prism::vtkPrismReaders)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target Prism::vtkPrismFilters 59 add_library(Prism::vtkPrismFilters SHARED IMPORTED) 61 set_target_properties(Prism::vtkPrismFilters PROPERTIES 62 INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel
" 65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 66 target_sources(Prism::vtkPrismFilters 68 FILE_SET "vtk_module_templates
" 70 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 73 FILE_SET "vtk_module_headers
" 75 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 76 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismGeometryConverter.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSimulationPointCloudFilter.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSimulationToPrismFilter.h
" 78 FILE_SET "vtk_module_nowrap_headers
" 80 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 81 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismFiltersModule.h
" 84 set_property(TARGET Prism::vtkPrismFilters 85 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 86 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 87 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 88 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 92 # Create imported target Prism::vtkPrismViews 93 add_library(Prism::vtkPrismViews SHARED IMPORTED) 95 set_target_properties(Prism::vtkPrismViews PROPERTIES 96 INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::CommonExecutionModel;VTK::PythonUsed
" 99 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 100 target_sources(Prism::vtkPrismViews 102 FILE_SET "vtk_module_templates
" 104 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 107 FILE_SET "vtk_module_headers
" 109 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 110 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismGeometryRepresentation.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismGeometryRepresentationWithFaces.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismSelectionRepresentation.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismView.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSMPrismViewProxy.h
" 112 FILE_SET "vtk_module_nowrap_headers
" 114 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 115 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismViewsModule.h
" 118 set_property(TARGET Prism::vtkPrismViews 119 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 120 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 121 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 122 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 126 # Create imported target Prism::vtkPrismServerManager 127 add_library(Prism::vtkPrismServerManager SHARED IMPORTED) 129 set_target_properties(Prism::vtkPrismServerManager PROPERTIES 130 INTERFACE_LINK_LIBRARIES "ParaView::RemotingServerManager;VTK::CommonExecutionModel;VTK::PythonUsed
" 133 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 134 target_sources(Prism::vtkPrismServerManager 136 FILE_SET "vtk_module_templates
" 138 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 141 FILE_SET "vtk_module_headers
" 143 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 144 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSMPrismIsSimulationDataDomain.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSMPrismTableArraysDomain.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSMPrismThresholdRangeDomain.h
" 146 FILE_SET "vtk_module_nowrap_headers
" 148 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 149 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismServerManagerModule.h
" 152 set_property(TARGET Prism::vtkPrismServerManager 153 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 154 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 155 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 156 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 160 # Create imported target Prism::vtkPrismReaders 161 add_library(Prism::vtkPrismReaders SHARED IMPORTED) 163 set_target_properties(Prism::vtkPrismReaders PROPERTIES 164 INTERFACE_LINK_LIBRARIES "ParaView::VTKExtensionsIOCore;Prism::vtkPrismServerManager;VTK::CommonExecutionModel;VTK::PythonUsed
" 167 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 168 target_sources(Prism::vtkPrismReaders 170 FILE_SET "vtk_module_templates
" 172 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 175 FILE_SET "vtk_module_headers
" 177 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 178 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismSESAMEFileSeriesReader.h
" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismSESAMEReader.h
" 180 FILE_SET "vtk_module_nowrap_headers
" 182 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 183 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkPrismReadersModule.h
" 186 set_property(TARGET Prism::vtkPrismReaders 187 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 188 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 189 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 190 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 194 # Load information for each installed configuration. 195 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/Prism-targets-*.cmake
") 196 foreach(_cmake_config_file IN LISTS _cmake_config_files) 197 include("${_cmake_config_file}
") 199 unset(_cmake_config_file) 200 unset(_cmake_config_files) 202 # Cleanup temporary variables. 205 # Loop over all imported files and verify that they actually exist 206 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 207 if(CMAKE_VERSION VERSION_LESS "3.28
" 208 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 209 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 210 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 211 if(NOT EXISTS "${_cmake_file}
") 212 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 214 but this file does not exist. Possible reasons include: 215 * The file was deleted, renamed, or moved to another location. 216 * An install or uninstall procedure did not complete successfully. 217 * The installation package was faulty and contained 218 \"${CMAKE_CURRENT_LIST_FILE}\" 219 but not all the files it references. 225 unset("_cmake_import_check_files_for_${_cmake_target}
") 228 unset(_cmake_import_check_targets) 230 # Make sure the targets which have been exported in some other 232 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 233 foreach(_target "VTK::CommonExecutionModel
" "ParaView::RemotingViews
" "VTK::PythonUsed
" "ParaView::RemotingServerManager
" "ParaView::VTKExtensionsIOCore
" ) 234 if(NOT TARGET "${_target}
" ) 235 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 239 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 240 if(CMAKE_FIND_PACKAGE_NAME) 241 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 242 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 244 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 247 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 249 # Commands beyond this point should not need to know the version. 250 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
