PanoramicProjectionView-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7  message(FATAL_ERROR "CMake >= 2.8.12 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.12...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS PanoramicProjectionView::vtkPanoramicProjectionViews)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target PanoramicProjectionView::vtkPanoramicProjectionViews
59 add_library(PanoramicProjectionView::vtkPanoramicProjectionViews SHARED IMPORTED)
60
61 set_target_properties(PanoramicProjectionView::vtkPanoramicProjectionViews PROPERTIES
62  INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::CommonCore;VTK::PythonUsed"
63 )
64
65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
66  target_sources(PanoramicProjectionView::vtkPanoramicProjectionViews
67  INTERFACE
68  FILE_SET "vtk_module_templates"
69  TYPE "HEADERS"
70  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
71  FILES
72  INTERFACE
73  FILE_SET "vtk_module_headers"
74  TYPE "HEADERS"
75  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
76  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPVPanoramicProjectionView.h"
77  INTERFACE
78  FILE_SET "vtk_module_nowrap_headers"
79  TYPE "HEADERS"
80  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
81  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPanoramicProjectionViewsModule.h"
82  )
83 else()
84  set_property(TARGET PanoramicProjectionView::vtkPanoramicProjectionViews
85  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
86  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
87  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
88  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
89  )
90 endif()
91
92 # Load information for each installed configuration.
93 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/PanoramicProjectionView-targets-*.cmake")
94 foreach(_cmake_config_file IN LISTS _cmake_config_files)
95  include("${_cmake_config_file}")
96 endforeach()
97 unset(_cmake_config_file)
98 unset(_cmake_config_files)
99
100 # Cleanup temporary variables.
101 set(_IMPORT_PREFIX)
102
103 # Loop over all imported files and verify that they actually exist
104 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
105  if(CMAKE_VERSION VERSION_LESS "3.28"
106  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
107  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
108  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
109  if(NOT EXISTS "${_cmake_file}")
110  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
111  \"${_cmake_file}\"
112 but this file does not exist. Possible reasons include:
113 * The file was deleted, renamed, or moved to another location.
114 * An install or uninstall procedure did not complete successfully.
115 * The installation package was faulty and contained
116  \"${CMAKE_CURRENT_LIST_FILE}\"
117 but not all the files it references.
118 ")
119  endif()
120  endforeach()
121  endif()
122  unset(_cmake_file)
123  unset("_cmake_import_check_files_for_${_cmake_target}")
124 endforeach()
125 unset(_cmake_target)
126 unset(_cmake_import_check_targets)
127
128 # Make sure the targets which have been exported in some other
129 # export set exist.
130 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
131 foreach(_target "ParaView::RemotingViews" "VTK::CommonCore" "VTK::PythonUsed" )
132  if(NOT TARGET "${_target}" )
133  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
134  endif()
135 endforeach()
136
137 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
138  if(CMAKE_FIND_PACKAGE_NAME)
139  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
140  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
141  else()
142  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
143  endif()
144 endif()
145 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
146
147 # Commands beyond this point should not need to know the version.
148 set(CMAKE_IMPORT_FILE_VERSION)
149 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
