1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/NetCDFTimeAnnotationPlugin
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
46  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so" AND
47  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so")
48  file(RPATH_CHECK
49  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so"
50  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
51  endif()
52  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so")
53  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so" AND
54  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so")
55  file(RPATH_CHANGE
56  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so"
57  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:"
58  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
59  if(CMAKE_INSTALL_DO_STRIP)
60  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/NetCDFTimeAnnotationPlugin/NetCDFTimeAnnotationPlugin.so")
61  endif()
62  endif()
63 endif()
64
65 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
66  # Include the install script for the subdirectory.
67  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/NetCDFTimeAnnotationPlugin/Testing/cmake_install.cmake")
68 endif()
69
