1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator
47  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel/cmake_install.cmake")
53 endif()
54
55 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
56  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/LegacyGhostCellsGenerator-targets.cmake")
57  file(DIFFERENT _cmake_export_file_changed FILES
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/LegacyGhostCellsGenerator-targets.cmake"
59  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/Export/9e46d3f506773a16a8c3559c1dbd58c7/LegacyGhostCellsGenerator-targets.cmake")
60  if(_cmake_export_file_changed)
61  file(GLOB _cmake_old_config_files "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/LegacyGhostCellsGenerator-targets-*.cmake")
62  if(_cmake_old_config_files)
63  string(REPLACE ";" ", " _cmake_old_config_files_text "${_cmake_old_config_files}")
64  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/LegacyGhostCellsGenerator-targets.cmake\" will be replaced. Removing files [${_cmake_old_config_files_text}].")
65  unset(_cmake_old_config_files_text)
66  file(REMOVE ${_cmake_old_config_files})
67  endif()
68  unset(_cmake_old_config_files)
69  endif()
70  unset(_cmake_export_file_changed)
71  endif()
72  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/Export/9e46d3f506773a16a8c3559c1dbd58c7/LegacyGhostCellsGenerator-targets.cmake")
73  if(CMAKE_INSTALL_CONFIG_NAME MATCHES "^([Rr][Ee][Ll][Ee][Aa][Ss][Ee])$")
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/Export/9e46d3f506773a16a8c3559c1dbd58c7/LegacyGhostCellsGenerator-targets-release.cmake")
75  endif()
76 endif()
77
78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2" TYPE FILE RENAME "LegacyGhostCellsGenerator-vtk-module-properties.cmake" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/LegacyGhostCellsGenerator-vtk-module-properties.cmake.install")
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libLegacyGhostCellsGeneratorFiltersCS.a")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libLegacyGhostCellsGeneratorParallelCS.a")
88 endif()
89
90 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
91  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so" AND
92  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so")
93  file(RPATH_CHECK
94  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so"
95  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
96  endif()
97  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so")
98  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so" AND
99  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so")
100  file(RPATH_CHANGE
101  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so"
102  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator:/usr/lib64/openmpi/lib:"
103  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
104  if(CMAKE_INSTALL_DO_STRIP)
105  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so")
106  endif()
107  endif()
108 endif()
109
110 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
111  # Include the install script for the subdirectory.
112  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Testing/cmake_install.cmake")
113 endif()
114
