GeodesicMeasurement-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7  message(FATAL_ERROR "CMake >= 2.8.12 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.12...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS GeodesicMeasurement::GeodesicMeasurementFilters GeodesicMeasurement::FmmMesh)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target GeodesicMeasurement::GeodesicMeasurementFilters
59 add_library(GeodesicMeasurement::GeodesicMeasurementFilters SHARED IMPORTED)
60
61 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES
62  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
63 )
64
65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
66  target_sources(GeodesicMeasurement::GeodesicMeasurementFilters
67  INTERFACE
68  FILE_SET "vtk_module_templates"
69  TYPE "HEADERS"
70  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
71  FILES
72  INTERFACE
73  FILE_SET "vtk_module_headers"
74  TYPE "HEADERS"
75  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
76  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkFastMarchingGeodesicDistance.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkFastMarchingGeodesicPath.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkGeodesicsBetweenPoints.h" "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkPolyDataGeodesicDistance.h"
77  INTERFACE
78  FILE_SET "vtk_module_nowrap_headers"
79  TYPE "HEADERS"
80  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
81  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkGeodesicMeasurementFiltersModule.h"
82  )
83 else()
84  set_property(TARGET GeodesicMeasurement::GeodesicMeasurementFilters
85  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
86  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
87  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
88  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
89  )
90 endif()
91
92 # Create imported target GeodesicMeasurement::FmmMesh
93 add_library(GeodesicMeasurement::FmmMesh STATIC IMPORTED)
94
95 # Load information for each installed configuration.
96 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/GeodesicMeasurement-targets-*.cmake")
97 foreach(_cmake_config_file IN LISTS _cmake_config_files)
98  include("${_cmake_config_file}")
99 endforeach()
100 unset(_cmake_config_file)
101 unset(_cmake_config_files)
102
103 # Cleanup temporary variables.
104 set(_IMPORT_PREFIX)
105
106 # Loop over all imported files and verify that they actually exist
107 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
108  if(CMAKE_VERSION VERSION_LESS "3.28"
109  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
110  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
111  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
112  if(NOT EXISTS "${_cmake_file}")
113  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
114  \"${_cmake_file}\"
115 but this file does not exist. Possible reasons include:
116 * The file was deleted, renamed, or moved to another location.
117 * An install or uninstall procedure did not complete successfully.
118 * The installation package was faulty and contained
119  \"${CMAKE_CURRENT_LIST_FILE}\"
120 but not all the files it references.
121 ")
122  endif()
123  endforeach()
124  endif()
125  unset(_cmake_file)
126  unset("_cmake_import_check_files_for_${_cmake_target}")
127 endforeach()
128 unset(_cmake_target)
129 unset(_cmake_import_check_targets)
130
131 # Make sure the targets which have been exported in some other
132 # export set exist.
133 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
134 foreach(_target "VTK::CommonExecutionModel" )
135  if(NOT TARGET "${_target}" )
136  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
137  endif()
138 endforeach()
139
140 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
141  if(CMAKE_FIND_PACKAGE_NAME)
142  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
143  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
144  else()
145  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
146  endif()
147 endif()
148 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
149
150 # Commands beyond this point should not need to know the version.
151 set(CMAKE_IMPORT_FILE_VERSION)
152 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
