3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7 message(FATAL_ERROR "CMake >= 2.8.12 required")
10 cmake_policy(
VERSION 2.8.12...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS GenericIOReader::vtkGenericIOReader GenericIOReader::LANL_GenericIO)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target GenericIOReader::vtkGenericIOReader 59 add_library(GenericIOReader::vtkGenericIOReader SHARED IMPORTED) 61 set_target_properties(GenericIOReader::vtkGenericIOReader PROPERTIES 62 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelCore;VTK::ParallelMPI;GenericIOReader::LANL_GenericIO
" 65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 66 target_sources(GenericIOReader::vtkGenericIOReader 68 FILE_SET "vtk_module_templates
" 70 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 73 FILE_SET "vtk_module_headers
" 75 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 76 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkGenIOReader.h
" 78 FILE_SET "vtk_module_nowrap_headers
" 80 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 81 FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkGenericIOReaderModule.h
" 84 set_property(TARGET GenericIOReader::vtkGenericIOReader 85 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 86 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 87 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 88 "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins
" 92 # Create imported target GenericIOReader::LANL_GenericIO 93 add_library(GenericIOReader::LANL_GenericIO STATIC IMPORTED) 95 set_target_properties(GenericIOReader::LANL_GenericIO PROPERTIES 96 INTERFACE_COMPILE_DEFINITIONS "LANL_GENERICIO_NO_MPI
" 99 # Load information for each installed configuration. 100 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/GenericIOReader-targets-*.cmake
") 101 foreach(_cmake_config_file IN LISTS _cmake_config_files) 102 include("${_cmake_config_file}
") 104 unset(_cmake_config_file) 105 unset(_cmake_config_files) 107 # Cleanup temporary variables. 110 # Loop over all imported files and verify that they actually exist 111 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 112 if(CMAKE_VERSION VERSION_LESS "3.28
" 113 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 114 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 115 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 116 if(NOT EXISTS "${_cmake_file}
") 117 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 119 but this file does not exist. Possible reasons include: 120 * The file was deleted, renamed, or moved to another location. 121 * An install or uninstall procedure did not complete successfully. 122 * The installation package was faulty and contained 123 \"${CMAKE_CURRENT_LIST_FILE}\" 124 but not all the files it references. 130 unset("_cmake_import_check_files_for_${_cmake_target}
") 133 unset(_cmake_import_check_targets) 135 # Make sure the targets which have been exported in some other 137 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 138 foreach(_target "VTK::CommonCore
" "VTK::CommonDataModel
" "VTK::CommonExecutionModel
" "VTK::ParallelCore
" "VTK::ParallelMPI
" ) 139 if(NOT TARGET "${_target}
" ) 140 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 144 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 145 if(CMAKE_FIND_PACKAGE_NAME) 146 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 147 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 149 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 152 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 154 # Commands beyond this point should not need to know the version. 155 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
