1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/EULATestPlugin 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"plugins" OR NOT CMAKE_INSTALL_COMPONENT)
46 if(EXISTS
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so" AND
47 NOT IS_SYMLINK
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so")
49 FILE
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so" 50 RPATH
"\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
52 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin
" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so
") 53 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so
" AND 54 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so
") 56 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so
" 57 OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:
" 58 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 59 if(CMAKE_INSTALL_DO_STRIP) 60 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/EULATestPlugin/EULATestPlugin.so
