1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/DigitalSignalProcessing/vtk/hierarchy/DigitalSignalProcessing" TYPE FILE RENAME "vtkDSPDataModel-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/DigitalSignalProcessing/vtk/hierarchy/DigitalSignalProcessing/vtkDSPDataModel-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/DigitalSignalProcessing" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/DigitalSignalProcessing/libvtkDSPDataModel.a")
51 endif()
52
53 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
54 endif()
55
56 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
57 endif()
58
59 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
60  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins" TYPE FILE FILES
61  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkArrayDispatchDSPArrayList.h"
62  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalArray.h"
63  "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalImplicitBackend.h"
64  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/vtkDSPDataModelModule.h"
65  )
66 endif()
67
68 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
69  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/vtkDSPDataModel.spdx")
70 endif()
71
