DigitalSignalProcessing-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7  message(FATAL_ERROR "CMake >= 2.8.12 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.12...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS DigitalSignalProcessing::DSPDataModel DigitalSignalProcessing::DSPFiltersPlugin)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target DigitalSignalProcessing::DSPDataModel
59 add_library(DigitalSignalProcessing::DSPDataModel STATIC IMPORTED)
60
61 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES
62  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonExecutionModel;\$<LINK_ONLY:VTK::CommonDataModel>"
63 )
64
65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
66  target_sources(DigitalSignalProcessing::DSPDataModel
67  INTERFACE
68  FILE_SET "vtk_module_templates"
69  TYPE "HEADERS"
70  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
71  FILES
72  INTERFACE
73  FILE_SET "vtk_module_headers"
74  TYPE "HEADERS"
75  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
76  FILES
77  INTERFACE
78  FILE_SET "vtk_module_nowrap_headers"
79  TYPE "HEADERS"
80  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
81  FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkArrayDispatchDSPArrayList.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkMultiDimensionalArray.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkMultiDimensionalImplicitBackend.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkDSPDataModelModule.h"
82  )
83 else()
84  set_property(TARGET DigitalSignalProcessing::DSPDataModel
85  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
86  "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
87  "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
88  "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
89  )
90 endif()
91
92 # Create imported target DigitalSignalProcessing::DSPFiltersPlugin
93 add_library(DigitalSignalProcessing::DSPFiltersPlugin STATIC IMPORTED)
94
95 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES
96  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::FiltersGeneral;\$<LINK_ONLY:DigitalSignalProcessing::DSPDataModel>;\$<LINK_ONLY:VTK::FiltersCore>;\$<LINK_ONLY:VTK::FiltersExtraction>;\$<LINK_ONLY:VTK::ParallelCore>"
97 )
98
99 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
100  target_sources(DigitalSignalProcessing::DSPFiltersPlugin
101  INTERFACE
102  FILE_SET "vtk_module_templates"
103  TYPE "HEADERS"
104  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
105  FILES
106  INTERFACE
107  FILE_SET "vtk_module_headers"
108  TYPE "HEADERS"
109  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
110  FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkAccousticUtilities.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkBandFiltering.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkDSPTableFFT.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkMeanPowerSpectralDensity.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkMergeReduceTables.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkMultiDimensionBrowser.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkProjectSpectrumMagnitude.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSoundQuantitiesCalculator.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkSpectrogramFilter.h" "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkTemporalMultiplexing.h"
111  INTERFACE
112  FILE_SET "vtk_module_nowrap_headers"
113  TYPE "HEADERS"
114  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
115  FILES "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins/vtkDSPFiltersPluginModule.h"
116  )
117 else()
118  set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin
119  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
120  "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
121  "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
122  "${_IMPORT_PREFIX}/include/paraview-6.2/ParaView_paraview_plugins"
123  )
124 endif()
125
126 # Load information for each installed configuration.
127 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/DigitalSignalProcessing-targets-*.cmake")
128 foreach(_cmake_config_file IN LISTS _cmake_config_files)
129  include("${_cmake_config_file}")
130 endforeach()
131 unset(_cmake_config_file)
132 unset(_cmake_config_files)
133
134 # Cleanup temporary variables.
135 set(_IMPORT_PREFIX)
136
137 # Loop over all imported files and verify that they actually exist
138 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
139  if(CMAKE_VERSION VERSION_LESS "3.28"
140  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
141  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
142  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
143  if(NOT EXISTS "${_cmake_file}")
144  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
145  \"${_cmake_file}\"
146 but this file does not exist. Possible reasons include:
147 * The file was deleted, renamed, or moved to another location.
148 * An install or uninstall procedure did not complete successfully.
149 * The installation package was faulty and contained
150  \"${CMAKE_CURRENT_LIST_FILE}\"
151 but not all the files it references.
152 ")
153  endif()
154  endforeach()
155  endif()
156  unset(_cmake_file)
157  unset("_cmake_import_check_files_for_${_cmake_target}")
158 endforeach()
159 unset(_cmake_target)
160 unset(_cmake_import_check_targets)
161
162 # Make sure the targets which have been exported in some other
163 # export set exist.
164 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
165 foreach(_target "VTK::CommonCore" "VTK::CommonExecutionModel" "VTK::CommonDataModel" "VTK::FiltersGeneral" "VTK::FiltersCore" "VTK::FiltersExtraction" "VTK::ParallelCore" )
166  if(NOT TARGET "${_target}" )
167  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
168  endif()
169 endforeach()
170
171 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
172  if(CMAKE_FIND_PACKAGE_NAME)
173  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
174  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
175  else()
176  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
177  endif()
178 endif()
179 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
180
181 # Commands beyond this point should not need to know the version.
182 set(CMAKE_IMPORT_FILE_VERSION)
183 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
