1 if (NOT (DEFINED paraview_cmake_dir AND
2 DEFINED paraview_cmake_build_dir AND
3 DEFINED paraview_cmake_destination AND
4 DEFINED paraview_modules))
6 "ParaViewInstallCMakePackage is missing input variables.")
9 _vtk_module_write_import_prefix("${paraview_cmake_build_dir}/paraview-prefix.cmake
" "${paraview_cmake_destination}
") 11 set(paraview_has_catalyst 0) 12 set(paraview_catalyst_directory "") 13 if (TARGET ParaView::catalyst-paraview) 14 set(paraview_has_catalyst 1) 15 get_property(paraview_catalyst_directory GLOBAL 16 PROPERTY paraview_catalyst_directory) 19 string(REPLACE "ParaView::
" "" _paraview_all_components "${paraview_modules};${paraview_client_modules}
") 22 "${paraview_cmake_dir}/paraview-config.cmake.in
" 23 "${paraview_cmake_build_dir}/paraview-config.cmake
" 25 include(CMakePackageConfigHelpers) 26 write_basic_package_version_file("${paraview_cmake_build_dir}/paraview-config-
version.cmake
" 28 COMPATIBILITY AnyNewerVersion) 30 # For convenience, a package is written to the top of the build tree. At some 31 # point, this should probably be deprecated and warn when it is used. 33 OUTPUT "${CMAKE_BINARY_DIR}/paraview-config.cmake
" 34 CONTENT "include(\
"${paraview_cmake_build_dir}/paraview-config.cmake\")\n")
36 "${paraview_cmake_build_dir}/paraview-config-
version.cmake
" 37 "${CMAKE_BINARY_DIR}/paraview-config-
version.cmake
" 40 set(paraview_cmake_module_files 42 paraview-use-file-compat.cmake 43 paraview-use-file-deprecated.cmake 44 paraview-use-file-error.cmake 47 paraview_client_initializer.cxx.in 48 paraview_client_initializer.h.in 49 paraview_client_main.cxx.in 51 paraview_servermanager_convert_categoryindex.xsl 52 paraview_servermanager_convert_html.xsl 53 paraview_servermanager_convert_wiki.xsl.in 54 paraview_servermanager_convert_xml.xsl 57 paraview_plugin.cxx.in 60 pqActionGroupImplementation.cxx.in 61 pqActionGroupImplementation.h.in 62 pqAutoStartImplementation.cxx.in 63 pqAutoStartImplementation.h.in 64 pqDockWindowImplementation.cxx.in 65 pqDockWindowImplementation.h.in 66 pqGraphLayoutStrategyImplementation.cxx.in 67 pqGraphLayoutStrategyImplementation.h.in 68 pqPluginLocationImplementation.cxx.in 69 pqPluginLocationImplementation.h.in 70 pqPropertyWidgetInterface.cxx.in 71 pqPropertyWidgetInterface.h.in 72 pqServerManagerModelImplementation.cxx.in 73 pqServerManagerModelImplementation.h.in 74 pqToolBarImplementation.cxx.in 75 pqToolBarImplementation.h.in 76 pqTreeLayoutStrategyImplementation.cxx.in 77 pqTreeLayoutStrategyImplementation.h.in 80 ParaViewServerManager.cmake 86 vtkModuleWrapClientServer.cmake 89 ParaViewTranslations.cmake 90 XML_translations_header_generator.py) 92 # From the `GmshIO` plugin. 93 if (TARGET GmshIO::vtkGmshIO) 94 list(APPEND paraview_cmake_module_files 98 set(paraview_cmake_files_to_install) 99 foreach (paraview_cmake_module_file IN LISTS paraview_cmake_module_files) 101 "${paraview_cmake_dir}/${paraview_cmake_module_file}
" 102 "${paraview_cmake_build_dir}/${paraview_cmake_module_file}
" 104 list(APPEND paraview_cmake_files_to_install 105 "${paraview_cmake_module_file}
") 108 if (PARAVIEW_ENABLE_VISITBRIDGE) 109 set(paraview_visitbridge_cmake_module_files 115 foreach (paraview_cmake_module_file IN LISTS paraview_visitbridge_cmake_module_files) 117 "${ParaView_SOURCE_DIR}/Utilities/VisItBridge/databases/cmake/${paraview_cmake_module_file}
" 118 "${paraview_cmake_build_dir}/${paraview_cmake_module_file}
" 120 list(APPEND paraview_cmake_files_to_install 121 "${paraview_cmake_build_dir}/${paraview_cmake_module_file}
") 125 include(ParaViewInstallCMakePackageHelpers) 126 if (NOT PARAVIEW_RELOCATABLE_INSTALL) 127 list(APPEND paraview_cmake_files_to_install 128 "${paraview_cmake_build_dir}/paraview-find-package-helpers.cmake
") 131 foreach (paraview_cmake_file IN LISTS paraview_cmake_files_to_install) 132 if (IS_ABSOLUTE "${paraview_cmake_file}
") 133 file(RELATIVE_PATH paraview_cmake_subdir_root "${paraview_cmake_build_dir}
" "${paraview_cmake_file}
") 134 get_filename_component(paraview_cmake_subdir "${paraview_cmake_subdir_root}
" DIRECTORY) 135 set(paraview_cmake_original_file "${paraview_cmake_file}
") 137 get_filename_component(paraview_cmake_subdir "${paraview_cmake_file}
" DIRECTORY) 138 set(paraview_cmake_original_file "${paraview_cmake_dir}/${paraview_cmake_file}
") 141 FILES "${paraview_cmake_original_file}
" 142 DESTINATION "${paraview_cmake_destination}/${paraview_cmake_subdir}
" 143 COMPONENT "development
") 147 FILES "${paraview_cmake_build_dir}/paraview-config.cmake
" 148 "${paraview_cmake_build_dir}/paraview-config-
version.cmake
" 149 "${paraview_cmake_build_dir}/paraview-prefix.cmake
" 150 DESTINATION "${paraview_cmake_destination}
" 151 COMPONENT "development
") 153 vtk_module_export_find_packages( 154 CMAKE_DESTINATION "${paraview_cmake_destination}
" 155 FILE_NAME "ParaView-
vtk-module-find-packages.cmake
" 156 MODULES ${paraview_modules}) 158 vtk_module_export_find_packages( 159 CMAKE_DESTINATION "${paraview_cmake_destination}
" 160 FILE_NAME "ParaViewIncubator-
" 161 MODULES ${paraview_incubator_modules}) 164 get_property(paraview_client_xml_files GLOBAL 165 PROPERTY paraview_client_xml_files) 166 get_property(paraview_client_xml_destination GLOBAL 167 PROPERTY paraview_client_xml_destination) 169 set(cmake_xml_file_name "ParaView-client-xml.cmake
") 170 set(cmake_xml_build_file "${paraview_cmake_build_dir}/${cmake_xml_file_name}
") 171 set(cmake_xml_install_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${cmake_xml_file_name}.install
") 173 file(WRITE "${cmake_xml_build_file}
" "") 174 file(WRITE "${cmake_xml_install_file}
" "") 175 _vtk_module_write_import_prefix("${cmake_xml_install_file}
" "${paraview_client_xml_destination}
") 176 file(APPEND "${cmake_xml_build_file}
" 177 "set(\
"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\")\n")
178 file(APPEND
"${cmake_xml_install_file}" 179 "set(\"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\")\n")
181 foreach (paraview_client_xml_file IN LISTS paraview_client_xml_files)
182 get_filename_component(basename
"${paraview_client_xml_file}" NAME)
183 file(APPEND
"${cmake_xml_build_file}" 184 "list(APPEND \"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\" 185 \"${paraview_client_xml_file}\")\n")
186 file(APPEND
"${cmake_xml_install_file}" 187 "list(APPEND \"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\" 188 \"\${_vtk_module_import_prefix}/${paraview_client_xml_destination}/${basename}\")\n")
192 FILES "${cmake_xml_install_file}
" 193 DESTINATION "${paraview_cmake_destination}
" 194 RENAME "${cmake_xml_file_name}
" 195 COMPONENT "development
") 198 # Expose ParaView_QCH_FILES variable used to locate where ParaView .qch help files are located. 199 # For now, it contains only the location of the `paraview.qch` file. 200 # To handle this location, which can vary between build and install dir, it is exposed via 201 # a specifc cmake file generate at build time. 203 get_property(paraview_qch_build_file GLOBAL PROPERTY paraview_qch_build_file) 204 get_property(paraview_qch_install_file GLOBAL PROPERTY paraview_qch_install_file) 206 set(cmake_qch_name "ParaView-client-qch.cmake
") 207 set(cmake_qch_build_file "${paraview_cmake_build_dir}/${cmake_qch_name}
") 208 set(cmake_qch_install_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${cmake_qch_name}.install
") 210 file(WRITE "${cmake_qch_build_file}
" "") 211 file(WRITE "${cmake_qch_install_file}
" "") 213 file(APPEND "${cmake_qch_build_file}
" 214 "set(\
"\${CMAKE_FIND_PACKAGE_NAME}_QCH_FILES\" \"${paraview_qch_build_file}\")\n")
216 _vtk_module_write_import_prefix(
"${cmake_qch_install_file}" "${CMAKE_INSTALL_DOCDIR}")
217 file(APPEND "${cmake_qch_install_file}
" 218 "list(APPEND \
"\${CMAKE_FIND_PACKAGE_NAME}_QCH_FILES\" 219 \"\${_vtk_module_import_prefix}/${paraview_qch_install_file}\")\n")
222 FILES
"${cmake_qch_install_file}" 223 DESTINATION
"${paraview_cmake_destination}" 224 RENAME
"${cmake_qch_name}" 225 COMPONENT
"development")
#define PARAVIEW_VERSION_FULL
