1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Examples
46  # Include the install script for each subdirectory.
47  include("/builds/gitlab-kitware-sciviz-ci/build/Examples/Plugins/ComplexPythonArchitecture/Testing/cmake_install.cmake")
48  include("/builds/gitlab-kitware-sciviz-ci/build/Examples/Catalyst2/cmake_install.cmake")
49
50 endif()
51
