CTestTestfile.cmake
1 # CMake generated Testfile for
2 # Source directory: /builds/gitlab-kitware-sciviz-ci/Examples/Plugins/ComplexPythonArchitecture/Testing
3 # Build directory: /builds/gitlab-kitware-sciviz-ci/build/Examples/Plugins/ComplexPythonArchitecture/Testing
4 #
5 # This file includes the relevant testing commands required for
6 # testing this directory and lists subdirectories to be tested as well.
7 add_test(PythonParaViewExample-Plugins/ComplexPythonArchitecture-UsingPlugin "/builds/gitlab-kitware-sciviz-ci/build/bin/pvpython" "--dr" "/builds/gitlab-kitware-sciviz-ci/Examples/Plugins/ComplexPythonArchitecture/Testing/UsingPlugin.py" "-T")
8 set_tests_properties(PythonParaViewExample-Plugins/ComplexPythonArchitecture-UsingPlugin PROPERTIES ENVIRONMENT "VTK_TESTING=1;VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" FAIL_REGULAR_EXPRESSION "(
9 |^)ERROR: ;ERR\\|;instance(s)? still around|DeprecationWarning" LABELS "" SKIP_REGULAR_EXPRESSION "Attempt to use a texture buffer exceeding your hardware's limits;vulkan: No DRI3 support detected - required for presentation" SKIP_RETURN_CODE "125" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/VTK/CMake/vtkModuleTesting.cmake;898;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;8;vtk_add_test_python;/builds/gitlab-kitware-sciviz-ci/Examples/Plugins/ComplexPythonArchitecture/Testing/CMakeLists.txt;5;paraview_add_test_python;/builds/gitlab-kitware-sciviz-ci/Examples/Plugins/ComplexPythonArchitecture/Testing/CMakeLists.txt;0;")
