1 # Regression test driver for paraview/paraview#21133. 3 # QSettings(IniFormat, UserScope) reads/writes "$HOME/.config/<Organization>/ 4 # <Application>.ini" on linux/macOS, so a fake HOME pointed at a directory 5 # pre-populated with INI_FIXTURE lets this test start ParaView as if a 6 # custom shortcut had already been saved in a previous session, without 7 # touching real settings. 9 set(home_dir
"${TEMPORARY_DIR}/CustomShortcutsPersistenceHome")
10 file(REMOVE_RECURSE
"${home_dir}")
11 file(MAKE_DIRECTORY
"${home_dir}/.config/ParaView")
12 file(COPY
"${INI_FIXTURE}" DESTINATION
13 get_filename_component(ini_fixture_name
"${INI_FIXTURE}" NAME)
14 file(RENAME
"${home_dir}/.config/ParaView/${ini_fixture_name}" "${home_dir}/.config/ParaView/ParaView.ini")
16 set(ENV{HOME}
"${home_dir}")
17 set(ENV{DASHBOARD_TEST_FROM_CTEST}
"1")
20 COMMAND ${PARAVIEW_EXECUTABLE}
21 --test-script=${TEST_SCRIPT}
26 file(REMOVE_RECURSE
"${home_dir}")
29 message(FATAL_ERROR
"ParaView return value was ${rv}")
