CTestTestfile.cmake
1 # CMake generated Testfile for
2 # Source directory: /builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy
3 # Build directory: /builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/Testing/Legacy
4 #
5 # This file includes the relevant testing commands required for
6 # testing this directory and lists subdirectories to be tested as well.
7 add_test(Catalyst::Legacy::WaveletMiniApp.cpimport "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpimport.py")
8 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.cpimport PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;532;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;28;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
9 add_test(Catalyst::Legacy::WaveletMiniApp.cpprogrammablefilter "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpprogrammablefilter.py")
10 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.cpprogrammablefilter PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;532;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;28;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
11 add_test(Catalyst::Legacy::WaveletMiniApp.TestInput "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/TestInput.py")
12 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.TestInput PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;532;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;28;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
13 add_test(Catalyst::Legacy::WaveletMiniApp.PythonScriptTest "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/PythonScriptTest.py")
14 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.PythonScriptTest PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;532;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;28;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
15 add_test(Catalyst::Legacy::WaveletMiniApp.CatalystLoadVTKmFilterPlugin "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CatalystLoadVTKmFilterPlugin.py")
16 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.CatalystLoadVTKmFilterPlugin PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;532;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;28;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
17 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.cpimport "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpimport.py")
18 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.cpimport PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS "2" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;547;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;34;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
19 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.cpprogrammablefilter "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpprogrammablefilter.py")
20 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.cpprogrammablefilter PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS "2" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;547;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;34;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
21 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.TestInput "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/TestInput.py")
22 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.TestInput PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS "2" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;547;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;34;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
23 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.PythonScriptTest "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/PythonScriptTest.py")
24 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.PythonScriptTest PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS "2" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;547;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;34;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
25 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.CatalystLoadVTKmFilterPlugin "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.2" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CatalystLoadVTKmFilterPlugin.py")
26 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.CatalystLoadVTKmFilterPlugin PROPERTIES ENVIRONMENT ";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS "2" TIMEOUT_AFTER_MATCH "5;Couldn't find object\\;Endian handshake failed" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;240;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;547;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;34;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
