3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget ParaView::vtkRemotingClientServerStreamPython ParaView::vtkPVVersioningPython ParaView::vtkPVVTKExtensionsCorePython ParaView::vtkRemotingCorePython ParaView::vtkRemotingServerManagerPython ParaView::vtkRemotingViewsPython ParaView::vtkRemotingViewsPythonPython ParaView::vtkRemotingServerManagerPythonPython ParaView::vtkRemotingMiscPython ParaView::vtkPVVTKExtensionsExtractionPython ParaView::vtkRemotingLivePython ParaView::vtkRemotingImportPython ParaView::vtkRemotingExportPython ParaView::vtkRemotingApplicationComponentsPython ParaView::vtkRemotingApplicationPython ParaView::vtkPVVTKExtensionsIOCorePython ParaView::vtkRemotingAnimationPython ParaView::vtkPVVTKExtensionsInteractionStylePython ParaView::vtkRemotingSettingsPython ParaView::vtkPVVTKExtensionsPointsPython ParaView::vtkPVVTKExtensionsIOSPCTHPython ParaView::vtkPVVTKExtensionsIOCGNSWriterPython ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython ParaView::vtkPVVTKExtensionsIOImportPython ParaView::vtkPVVTKExtensionsIOImagePython ParaView::vtkPVVTKExtensionsIOGeneralPython ParaView::vtkPVVTKExtensionsIOExodusPython ParaView::vtkPVVTKExtensionsIOEnSightPython ParaView::vtkPVVTKExtensionsIOAMRPython ParaView::vtkPVVTKExtensionsFiltersStatisticsPython ParaView::vtkPVVTKExtensionsFiltersPythonPython ParaView::vtkPVVTKExtensionsFiltersGeneralPython ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python ParaView::vtkPVVTKExtensionsFiltersParallelPython ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::vtkPVVTKExtensionsFiltersRenderingPython ParaView::vtkPVVTKExtensionsMiscPython ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython ParaView::vtkPVVTKExtensionsExtractionPythonPython ParaView::vtkPVVTKExtensionsAMRPython ParaView::vtkPVCatalystPython ParaView::vtkPVCatalystTestDriverPython ParaView::vtkPVPythonCatalystPython ParaView::vtkPVClientWebPython ParaView::vtkPVInSituPython ParaView::pvpythonmodules)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Compute the installation prefix relative to this file. 45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 49 if(_IMPORT_PREFIX STREQUAL "/
") 50 set(_IMPORT_PREFIX "") 53 # Create imported target ParaView::vtkRemotingClientServerStreamPython 54 add_library(ParaView::vtkRemotingClientServerStreamPython MODULE IMPORTED) 56 # Create imported target ParaView::vtkPVVersioningPython 57 add_library(ParaView::vtkPVVersioningPython MODULE IMPORTED) 59 # Create imported target ParaView::vtkPVVTKExtensionsCorePython 60 add_library(ParaView::vtkPVVTKExtensionsCorePython MODULE IMPORTED) 62 # Create imported target ParaView::vtkRemotingCorePython 63 add_library(ParaView::vtkRemotingCorePython MODULE IMPORTED) 65 # Create imported target ParaView::vtkRemotingServerManagerPython 66 add_library(ParaView::vtkRemotingServerManagerPython MODULE IMPORTED) 68 # Create imported target ParaView::vtkRemotingViewsPython 69 add_library(ParaView::vtkRemotingViewsPython MODULE IMPORTED) 71 # Create imported target ParaView::vtkRemotingViewsPythonPython 72 add_library(ParaView::vtkRemotingViewsPythonPython MODULE IMPORTED) 74 # Create imported target ParaView::vtkRemotingServerManagerPythonPython 75 add_library(ParaView::vtkRemotingServerManagerPythonPython MODULE IMPORTED) 77 # Create imported target ParaView::vtkRemotingMiscPython 78 add_library(ParaView::vtkRemotingMiscPython MODULE IMPORTED) 80 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPython 81 add_library(ParaView::vtkPVVTKExtensionsExtractionPython MODULE IMPORTED) 83 # Create imported target ParaView::vtkRemotingLivePython 84 add_library(ParaView::vtkRemotingLivePython MODULE IMPORTED) 86 # Create imported target ParaView::vtkRemotingImportPython 87 add_library(ParaView::vtkRemotingImportPython MODULE IMPORTED) 89 # Create imported target ParaView::vtkRemotingExportPython 90 add_library(ParaView::vtkRemotingExportPython MODULE IMPORTED) 92 # Create imported target ParaView::vtkRemotingApplicationComponentsPython 93 add_library(ParaView::vtkRemotingApplicationComponentsPython MODULE IMPORTED) 95 # Create imported target ParaView::vtkRemotingApplicationPython 96 add_library(ParaView::vtkRemotingApplicationPython MODULE IMPORTED) 98 # Create imported target ParaView::vtkPVVTKExtensionsIOCorePython 99 add_library(ParaView::vtkPVVTKExtensionsIOCorePython MODULE IMPORTED) 101 # Create imported target ParaView::vtkRemotingAnimationPython 102 add_library(ParaView::vtkRemotingAnimationPython MODULE IMPORTED) 104 # Create imported target ParaView::vtkPVVTKExtensionsInteractionStylePython 105 add_library(ParaView::vtkPVVTKExtensionsInteractionStylePython MODULE IMPORTED) 107 # Create imported target ParaView::vtkRemotingSettingsPython 108 add_library(ParaView::vtkRemotingSettingsPython MODULE IMPORTED) 110 # Create imported target ParaView::vtkPVVTKExtensionsPointsPython 111 add_library(ParaView::vtkPVVTKExtensionsPointsPython MODULE IMPORTED) 113 # Create imported target ParaView::vtkPVVTKExtensionsIOSPCTHPython 114 add_library(ParaView::vtkPVVTKExtensionsIOSPCTHPython MODULE IMPORTED) 116 # Create imported target ParaView::vtkPVVTKExtensionsIOCGNSWriterPython 117 add_library(ParaView::vtkPVVTKExtensionsIOCGNSWriterPython MODULE IMPORTED) 119 # Create imported target ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython 120 add_library(ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython MODULE IMPORTED) 122 # Create imported target ParaView::vtkPVVTKExtensionsIOImportPython 123 add_library(ParaView::vtkPVVTKExtensionsIOImportPython MODULE IMPORTED) 125 # Create imported target ParaView::vtkPVVTKExtensionsIOImagePython 126 add_library(ParaView::vtkPVVTKExtensionsIOImagePython MODULE IMPORTED) 128 # Create imported target ParaView::vtkPVVTKExtensionsIOGeneralPython 129 add_library(ParaView::vtkPVVTKExtensionsIOGeneralPython MODULE IMPORTED) 131 # Create imported target ParaView::vtkPVVTKExtensionsIOExodusPython 132 add_library(ParaView::vtkPVVTKExtensionsIOExodusPython MODULE IMPORTED) 134 # Create imported target ParaView::vtkPVVTKExtensionsIOEnSightPython 135 add_library(ParaView::vtkPVVTKExtensionsIOEnSightPython MODULE IMPORTED) 137 # Create imported target ParaView::vtkPVVTKExtensionsIOAMRPython 138 add_library(ParaView::vtkPVVTKExtensionsIOAMRPython MODULE IMPORTED) 140 # Create imported target ParaView::vtkPVVTKExtensionsFiltersStatisticsPython 141 add_library(ParaView::vtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED) 143 # Create imported target ParaView::vtkPVVTKExtensionsFiltersPythonPython 144 add_library(ParaView::vtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED) 146 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralPython 147 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED) 149 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python 150 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python MODULE IMPORTED) 152 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelPython 153 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelPython MODULE IMPORTED) 155 # Create imported target ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython 156 add_library(ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED) 158 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython 159 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED) 161 # Create imported target ParaView::vtkPVVTKExtensionsFiltersRenderingPython 162 add_library(ParaView::vtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED) 164 # Create imported target ParaView::vtkPVVTKExtensionsMiscPython 165 add_library(ParaView::vtkPVVTKExtensionsMiscPython MODULE IMPORTED) 167 # Create imported target ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython 168 add_library(ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython MODULE IMPORTED) 170 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPythonPython 171 add_library(ParaView::vtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED) 173 # Create imported target ParaView::vtkPVVTKExtensionsAMRPython 174 add_library(ParaView::vtkPVVTKExtensionsAMRPython MODULE IMPORTED) 176 # Create imported target ParaView::vtkPVCatalystPython 177 add_library(ParaView::vtkPVCatalystPython MODULE IMPORTED) 179 # Create imported target ParaView::vtkPVCatalystTestDriverPython 180 add_library(ParaView::vtkPVCatalystTestDriverPython MODULE IMPORTED) 182 # Create imported target ParaView::vtkPVPythonCatalystPython 183 add_library(ParaView::vtkPVPythonCatalystPython MODULE IMPORTED) 185 # Create imported target ParaView::vtkPVClientWebPython 186 add_library(ParaView::vtkPVClientWebPython MODULE IMPORTED) 188 # Create imported target ParaView::vtkPVInSituPython 189 add_library(ParaView::vtkPVInSituPython MODULE IMPORTED) 191 # Create imported target ParaView::pvpythonmodules 192 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED) 194 set_target_properties(ParaView::pvpythonmodules PROPERTIES 195 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0/pvpythonmodules
" 196 INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules
" 199 if(CMAKE_VERSION VERSION_LESS 3.0.0) 200 message(FATAL_ERROR "This file relies
on consumers
using CMake 3.0.0 or greater.
") 203 # Load information for each installed configuration. 204 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}
" PATH) 206 foreach(f ${CONFIG_FILES}) 210 # Cleanup temporary variables. 213 # Loop over all imported files and verify that they actually exist 214 foreach(target ${_IMPORT_CHECK_TARGETS} ) 215 foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} ) 216 if(NOT EXISTS "${file}
" ) 217 message(FATAL_ERROR "The imported
target \
"${target}\" references the file 219 but this file does not exist. Possible reasons include: 220 * The file was deleted, renamed, or moved to another location. 221 * An install or uninstall procedure did not complete successfully. 222 * The installation package was faulty and contained 223 \"${CMAKE_CURRENT_LIST_FILE}\" 224 but not all the files it references. 228 unset(_IMPORT_CHECK_FILES_FOR_${
target})
230 unset(_IMPORT_CHECK_TARGETS)
232 # Make sure the targets which have been exported in some other 234 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
235 foreach(_target
"VTK::vtkpythonmodules" )
236 if(NOT TARGET
"${_target}" )
237 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets
"${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
241 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
242 if(CMAKE_FIND_PACKAGE_NAME)
243 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
244 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
"The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
246 message(FATAL_ERROR
249 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
251 # Commands beyond
this point should not need to know the
version.
252 set(CMAKE_IMPORT_FILE_VERSION)
