ParaViewIncubator-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget ParaViewIncubator::Core)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Compute the installation prefix relative to this file.
45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
49 if(_IMPORT_PREFIX STREQUAL "/")
50  set(_IMPORT_PREFIX "")
51 endif()
52
53 # Create imported target ParaViewIncubator::Core
54 add_library(ParaViewIncubator::Core SHARED IMPORTED)
55
56 set_target_properties(ParaViewIncubator::Core PROPERTIES
57  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0/Incubator"
58  INTERFACE_LINK_LIBRARIES "VTK::CommonCore"
59 )
60
61 if(CMAKE_VERSION VERSION_LESS 2.8.12)
62  message(FATAL_ERROR "This file relies on consumers using CMake 2.8.12 or greater.")
63 endif()
64
65 # Load information for each installed configuration.
66 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}" PATH)
67 file(GLOB CONFIG_FILES "${_DIR}/ParaViewIncubator-targets-*.cmake")
68 foreach(f ${CONFIG_FILES})
69  include(${f})
70 endforeach()
71
72 # Cleanup temporary variables.
73 set(_IMPORT_PREFIX)
74
75 # Loop over all imported files and verify that they actually exist
76 foreach(target ${_IMPORT_CHECK_TARGETS} )
77  foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} )
78  if(NOT EXISTS "${file}" )
79  message(FATAL_ERROR "The imported target \"${target}\" references the file
80  \"${file}\"
81 but this file does not exist. Possible reasons include:
82 * The file was deleted, renamed, or moved to another location.
83 * An install or uninstall procedure did not complete successfully.
84 * The installation package was faulty and contained
85  \"${CMAKE_CURRENT_LIST_FILE}\"
86 but not all the files it references.
87 ")
88  endif()
89  endforeach()
90  unset(_IMPORT_CHECK_FILES_FOR_${target})
91 endforeach()
92 unset(_IMPORT_CHECK_TARGETS)
93
94 # Make sure the targets which have been exported in some other
95 # export set exist.
96 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
97 foreach(_target "VTK::CommonCore" )
98  if(NOT TARGET "${_target}" )
99  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
100  endif()
101 endforeach()
102
103 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
104  if(CMAKE_FIND_PACKAGE_NAME)
105  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
106  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
107  else()
108  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
109  endif()
110 endif()
111 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
112
113 # Commands beyond this point should not need to know the version.
114 set(CMAKE_IMPORT_FILE_VERSION)
115 cmake_policy(POP)
on
version
#define VERSION
Definition: jconfigint.h:17
