ParaViewClients-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget ParaView::AdaptorsPython ParaView::Catalyst ParaView::Catalyst-private-kit-links ParaView::AdaptorsPhasta ParaView::AdaptorsParticle ParaView::PythonCatalyst ParaView::AdaptorsPagosa ParaView::AdaptorsNPIC ParaView::CatalystTestDriver ParaView::AdaptorsCam ParaView::AdaptorsCamPython ParaView::AdaptorsCTH ParaView::ClientsWeb ParaView::InSitu)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Compute the installation prefix relative to this file.
45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
49 if(_IMPORT_PREFIX STREQUAL "/")
50  set(_IMPORT_PREFIX "")
51 endif()
52
53 # Create imported target ParaView::AdaptorsPython
54 add_library(ParaView::AdaptorsPython INTERFACE IMPORTED)
55
56 # Create imported target ParaView::Catalyst
57 add_library(ParaView::Catalyst SHARED IMPORTED)
58
59 set_target_properties(ParaView::Catalyst PROPERTIES
60  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
61  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed"
62 )
63
64 # Create imported target ParaView::Catalyst-private-kit-links
65 add_library(ParaView::Catalyst-private-kit-links INTERFACE IMPORTED)
66
67 set_target_properties(ParaView::Catalyst-private-kit-links PROPERTIES
68  INTERFACE_LINK_LIBRARIES "\$<LINK_ONLY:ParaView::paraview_plugins>"
69 )
70
71 # Create imported target ParaView::AdaptorsPhasta
72 add_library(ParaView::AdaptorsPhasta SHARED IMPORTED)
73
74 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES
75  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
76  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::PythonUsed"
77 )
78
79 # Create imported target ParaView::AdaptorsParticle
80 add_library(ParaView::AdaptorsParticle SHARED IMPORTED)
81
82 set_target_properties(ParaView::AdaptorsParticle PROPERTIES
83  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
84  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::RemotingViews;VTK::CommonCore;VTK::CommonDataModel;VTK::IOImage;VTK::IOParallelXML;VTK::ParallelMPI;VTK::RenderingCore;VTK::RenderingOpenGL2;VTK::PythonUsed"
85 )
86
87 # Create imported target ParaView::PythonCatalyst
88 add_library(ParaView::PythonCatalyst SHARED IMPORTED)
89
90 set_target_properties(ParaView::PythonCatalyst PROPERTIES
91  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
92  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonInterpreter;ParaView::PythonInterpreterPath;VTK::PythonUsed"
93 )
94
95 # Create imported target ParaView::AdaptorsPagosa
96 add_library(ParaView::AdaptorsPagosa SHARED IMPORTED)
97
98 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES
99  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
100  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::PythonUsed"
101 )
102
103 # Create imported target ParaView::AdaptorsNPIC
104 add_library(ParaView::AdaptorsNPIC SHARED IMPORTED)
105
106 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES
107  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
108  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::ParallelMPI;VTK::PythonUsed"
109 )
110
111 # Create imported target ParaView::CatalystTestDriver
112 add_library(ParaView::CatalystTestDriver SHARED IMPORTED)
113
114 set_target_properties(ParaView::CatalystTestDriver PROPERTIES
115  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
116  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonUsed"
117 )
118
119 # Create imported target ParaView::AdaptorsCam
120 add_library(ParaView::AdaptorsCam SHARED IMPORTED)
121
122 set_target_properties(ParaView::AdaptorsCam PROPERTIES
123  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
124  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::PythonUsed"
125 )
126
127 # Create imported target ParaView::AdaptorsCamPython
128 add_library(ParaView::AdaptorsCamPython INTERFACE IMPORTED)
129
130 set_target_properties(ParaView::AdaptorsCamPython PROPERTIES
131  INTERFACE_LINK_LIBRARIES "ParaView::AdaptorsCam"
132 )
133
134 # Create imported target ParaView::AdaptorsCTH
135 add_library(ParaView::AdaptorsCTH SHARED IMPORTED)
136
137 set_target_properties(ParaView::AdaptorsCTH PROPERTIES
138  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
139  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelMPI;VTK::PythonUsed"
140 )
141
142 # Create imported target ParaView::ClientsWeb
143 add_library(ParaView::ClientsWeb SHARED IMPORTED)
144
145 set_target_properties(ParaView::ClientsWeb PROPERTIES
146  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
147  INTERFACE_LINK_LIBRARIES "VTK::WebCore;VTK::WebGLExporter;VTK::PythonUsed"
148 )
149
150 # Create imported target ParaView::InSitu
151 add_library(ParaView::InSitu SHARED IMPORTED)
152
153 set_target_properties(ParaView::InSitu PROPERTIES
154  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0"
155  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed"
156 )
157
158 if(CMAKE_VERSION VERSION_LESS 3.0.0)
159  message(FATAL_ERROR "This file relies on consumers using CMake 3.0.0 or greater.")
160 endif()
161
162 # Load information for each installed configuration.
163 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}" PATH)
164 file(GLOB CONFIG_FILES "${_DIR}/ParaViewClients-targets-*.cmake")
165 foreach(f ${CONFIG_FILES})
166  include(${f})
167 endforeach()
168
169 # Cleanup temporary variables.
170 set(_IMPORT_PREFIX)
171
172 # Loop over all imported files and verify that they actually exist
173 foreach(target ${_IMPORT_CHECK_TARGETS} )
174  foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} )
175  if(NOT EXISTS "${file}" )
176  message(FATAL_ERROR "The imported target \"${target}\" references the file
177  \"${file}\"
178 but this file does not exist. Possible reasons include:
179 * The file was deleted, renamed, or moved to another location.
180 * An install or uninstall procedure did not complete successfully.
181 * The installation package was faulty and contained
182  \"${CMAKE_CURRENT_LIST_FILE}\"
183 but not all the files it references.
184 ")
185  endif()
186  endforeach()
187  unset(_IMPORT_CHECK_FILES_FOR_${target})
188 endforeach()
189 unset(_IMPORT_CHECK_TARGETS)
190
191 # Make sure the targets which have been exported in some other
192 # export set exist.
193 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
194 foreach(_target "VTK::CommonCore" "VTK::PythonUsed" "ParaView::paraview_plugins" "VTK::CommonDataModel" "ParaView::RemotingViews" "VTK::IOImage" "VTK::IOParallelXML" "VTK::ParallelMPI" "VTK::RenderingCore" "VTK::RenderingOpenGL2" "VTK::PythonInterpreter" "ParaView::PythonInterpreterPath" "VTK::CommonExecutionModel" "VTK::WebCore" "VTK::WebGLExporter" )
195  if(NOT TARGET "${_target}" )
196  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
197  endif()
198 endforeach()
199
200 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
201  if(CMAKE_FIND_PACKAGE_NAME)
202  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
203  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
204  else()
205  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
206  endif()
207 endif()
208 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
209
210 # Commands beyond this point should not need to know the version.
211 set(CMAKE_IMPORT_FILE_VERSION)
212 cmake_policy(POP)
on
version
#define VERSION
Definition: jconfigint.h:17
