3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7 message(FATAL_ERROR "CMake >= 3.0.0 required")
10 cmake_policy(
VERSION 3.0.0...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParaView::vtkRemotingClientServerStreamPython ParaView::vtkPVVersioningPython ParaView::vtkPVVTKExtensionsCorePython ParaView::vtkRemotingCorePython ParaView::vtkRemotingServerManagerPython ParaView::vtkRemotingViewsPython ParaView::vtkRemotingViewsPythonPython ParaView::vtkRemotingServerManagerPythonPython ParaView::vtkRemotingMiscPython ParaView::vtkPVVTKExtensionsExtractionPython ParaView::vtkRemotingLivePython ParaView::vtkRemotingImportPython ParaView::vtkRemotingExportPython ParaView::vtkRemotingApplicationComponentsPython ParaView::vtkRemotingApplicationPython ParaView::vtkPVVTKExtensionsIOCorePython ParaView::vtkRemotingAnimationPython ParaView::vtkPVVTKExtensionsInteractionStylePython ParaView::vtkRemotingSettingsPython ParaView::vtkPVVTKExtensionsPointsPython ParaView::vtkPVVTKExtensionsIOSPCTHPython ParaView::vtkPVVTKExtensionsIOCGNSWriterPython ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython ParaView::vtkPVVTKExtensionsIOImportPython ParaView::vtkPVVTKExtensionsIOImagePython ParaView::vtkPVVTKExtensionsIOGeneralPython ParaView::vtkPVVTKExtensionsIOExodusPython ParaView::vtkPVVTKExtensionsIOEnSightPython ParaView::vtkPVVTKExtensionsIOAMRPython ParaView::vtkPVVTKExtensionsFiltersStatisticsPython ParaView::vtkPVVTKExtensionsFiltersPythonPython ParaView::vtkPVVTKExtensionsFiltersGeneralPython ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python ParaView::vtkPVVTKExtensionsFiltersParallelPython ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::vtkPVVTKExtensionsFiltersRenderingPython ParaView::vtkPVVTKExtensionsMiscPython ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython ParaView::vtkPVVTKExtensionsExtractionPythonPython ParaView::vtkPVVTKExtensionsAMRPython ParaView::vtkPVCatalystPython ParaView::vtkPVCatalystTestDriverPython ParaView::vtkPVPythonCatalystPython ParaView::vtkPVClientWebPython ParaView::vtkPVInSituPython ParaView::pvpythonmodules)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target ParaView::vtkRemotingClientServerStreamPython 59 add_library(ParaView::vtkRemotingClientServerStreamPython MODULE IMPORTED) 61 # Create imported target ParaView::vtkPVVersioningPython 62 add_library(ParaView::vtkPVVersioningPython MODULE IMPORTED) 64 # Create imported target ParaView::vtkPVVTKExtensionsCorePython 65 add_library(ParaView::vtkPVVTKExtensionsCorePython MODULE IMPORTED) 67 # Create imported target ParaView::vtkRemotingCorePython 68 add_library(ParaView::vtkRemotingCorePython MODULE IMPORTED) 70 # Create imported target ParaView::vtkRemotingServerManagerPython 71 add_library(ParaView::vtkRemotingServerManagerPython MODULE IMPORTED) 73 # Create imported target ParaView::vtkRemotingViewsPython 74 add_library(ParaView::vtkRemotingViewsPython MODULE IMPORTED) 76 # Create imported target ParaView::vtkRemotingViewsPythonPython 77 add_library(ParaView::vtkRemotingViewsPythonPython MODULE IMPORTED) 79 # Create imported target ParaView::vtkRemotingServerManagerPythonPython 80 add_library(ParaView::vtkRemotingServerManagerPythonPython MODULE IMPORTED) 82 # Create imported target ParaView::vtkRemotingMiscPython 83 add_library(ParaView::vtkRemotingMiscPython MODULE IMPORTED) 85 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPython 86 add_library(ParaView::vtkPVVTKExtensionsExtractionPython MODULE IMPORTED) 88 # Create imported target ParaView::vtkRemotingLivePython 89 add_library(ParaView::vtkRemotingLivePython MODULE IMPORTED) 91 # Create imported target ParaView::vtkRemotingImportPython 92 add_library(ParaView::vtkRemotingImportPython MODULE IMPORTED) 94 # Create imported target ParaView::vtkRemotingExportPython 95 add_library(ParaView::vtkRemotingExportPython MODULE IMPORTED) 97 # Create imported target ParaView::vtkRemotingApplicationComponentsPython 98 add_library(ParaView::vtkRemotingApplicationComponentsPython MODULE IMPORTED) 100 # Create imported target ParaView::vtkRemotingApplicationPython 101 add_library(ParaView::vtkRemotingApplicationPython MODULE IMPORTED) 103 # Create imported target ParaView::vtkPVVTKExtensionsIOCorePython 104 add_library(ParaView::vtkPVVTKExtensionsIOCorePython MODULE IMPORTED) 106 # Create imported target ParaView::vtkRemotingAnimationPython 107 add_library(ParaView::vtkRemotingAnimationPython MODULE IMPORTED) 109 # Create imported target ParaView::vtkPVVTKExtensionsInteractionStylePython 110 add_library(ParaView::vtkPVVTKExtensionsInteractionStylePython MODULE IMPORTED) 112 # Create imported target ParaView::vtkRemotingSettingsPython 113 add_library(ParaView::vtkRemotingSettingsPython MODULE IMPORTED) 115 # Create imported target ParaView::vtkPVVTKExtensionsPointsPython 116 add_library(ParaView::vtkPVVTKExtensionsPointsPython MODULE IMPORTED) 118 # Create imported target ParaView::vtkPVVTKExtensionsIOSPCTHPython 119 add_library(ParaView::vtkPVVTKExtensionsIOSPCTHPython MODULE IMPORTED) 121 # Create imported target ParaView::vtkPVVTKExtensionsIOCGNSWriterPython 122 add_library(ParaView::vtkPVVTKExtensionsIOCGNSWriterPython MODULE IMPORTED) 124 # Create imported target ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython 125 add_library(ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython MODULE IMPORTED) 127 # Create imported target ParaView::vtkPVVTKExtensionsIOImportPython 128 add_library(ParaView::vtkPVVTKExtensionsIOImportPython MODULE IMPORTED) 130 # Create imported target ParaView::vtkPVVTKExtensionsIOImagePython 131 add_library(ParaView::vtkPVVTKExtensionsIOImagePython MODULE IMPORTED) 133 # Create imported target ParaView::vtkPVVTKExtensionsIOGeneralPython 134 add_library(ParaView::vtkPVVTKExtensionsIOGeneralPython MODULE IMPORTED) 136 # Create imported target ParaView::vtkPVVTKExtensionsIOExodusPython 137 add_library(ParaView::vtkPVVTKExtensionsIOExodusPython MODULE IMPORTED) 139 # Create imported target ParaView::vtkPVVTKExtensionsIOEnSightPython 140 add_library(ParaView::vtkPVVTKExtensionsIOEnSightPython MODULE IMPORTED) 142 # Create imported target ParaView::vtkPVVTKExtensionsIOAMRPython 143 add_library(ParaView::vtkPVVTKExtensionsIOAMRPython MODULE IMPORTED) 145 # Create imported target ParaView::vtkPVVTKExtensionsFiltersStatisticsPython 146 add_library(ParaView::vtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED) 148 # Create imported target ParaView::vtkPVVTKExtensionsFiltersPythonPython 149 add_library(ParaView::vtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED) 151 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralPython 152 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED) 154 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python 155 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python MODULE IMPORTED) 157 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelPython 158 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelPython MODULE IMPORTED) 160 # Create imported target ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython 161 add_library(ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED) 163 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython 164 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED) 166 # Create imported target ParaView::vtkPVVTKExtensionsFiltersRenderingPython 167 add_library(ParaView::vtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED) 169 # Create imported target ParaView::vtkPVVTKExtensionsMiscPython 170 add_library(ParaView::vtkPVVTKExtensionsMiscPython MODULE IMPORTED) 172 # Create imported target ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython 173 add_library(ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython MODULE IMPORTED) 175 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPythonPython 176 add_library(ParaView::vtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED) 178 # Create imported target ParaView::vtkPVVTKExtensionsAMRPython 179 add_library(ParaView::vtkPVVTKExtensionsAMRPython MODULE IMPORTED) 181 # Create imported target ParaView::vtkPVCatalystPython 182 add_library(ParaView::vtkPVCatalystPython MODULE IMPORTED) 184 # Create imported target ParaView::vtkPVCatalystTestDriverPython 185 add_library(ParaView::vtkPVCatalystTestDriverPython MODULE IMPORTED) 187 # Create imported target ParaView::vtkPVPythonCatalystPython 188 add_library(ParaView::vtkPVPythonCatalystPython MODULE IMPORTED) 190 # Create imported target ParaView::vtkPVClientWebPython 191 add_library(ParaView::vtkPVClientWebPython MODULE IMPORTED) 193 # Create imported target ParaView::vtkPVInSituPython 194 add_library(ParaView::vtkPVInSituPython MODULE IMPORTED) 196 # Create imported target ParaView::pvpythonmodules 197 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED) 199 set_target_properties(ParaView::pvpythonmodules PROPERTIES 200 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.1/pvpythonmodules
" 201 INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules
" 204 # Load information for each installed configuration. 205 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/
ParaViewPython-targets-*.cmake
") 206 foreach(_cmake_config_file IN LISTS _cmake_config_files) 207 include("${_cmake_config_file}
") 209 unset(_cmake_config_file) 210 unset(_cmake_config_files) 212 # Cleanup temporary variables. 215 # Loop over all imported files and verify that they actually exist 216 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 217 if(CMAKE_VERSION VERSION_LESS "3.28
" 218 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 219 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 220 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 221 if(NOT EXISTS "${_cmake_file}
") 222 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 224 but this file does not exist. Possible reasons include: 225 * The file was deleted, renamed, or moved to another location. 226 * An install or uninstall procedure did not complete successfully. 227 * The installation package was faulty and contained 228 \"${CMAKE_CURRENT_LIST_FILE}\" 229 but not all the files it references. 235 unset("_cmake_import_check_files_for_${_cmake_target}
") 238 unset(_cmake_import_check_targets) 240 # Make sure the targets which have been exported in some other 242 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 243 foreach(_target "VTK::vtkpythonmodules
" ) 244 if(NOT TARGET "${_target}
" ) 245 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 249 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 250 if(CMAKE_FIND_PACKAGE_NAME) 251 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 252 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 254 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 257 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 259 # Commands beyond this point should not need to know the version. 260 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
