3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7 message(FATAL_ERROR "CMake >= 3.0.0 required")
10 cmake_policy(
VERSION 3.0.0...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParaView::PyvtkPVIncubatorCorePython ParaView::pvincubatorpythonmodules)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target ParaView::PyvtkPVIncubatorCorePython 59 add_library(ParaView::PyvtkPVIncubatorCorePython MODULE IMPORTED) 61 # Create imported target ParaView::pvincubatorpythonmodules 62 add_library(ParaView::pvincubatorpythonmodules INTERFACE IMPORTED) 64 set_target_properties(ParaView::pvincubatorpythonmodules PROPERTIES 65 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/pvincubatorpythonmodules
" 66 INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules
" 69 # Load information for each installed configuration. 70 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/ParaViewPythonIncubator-targets-*.cmake
") 71 foreach(_cmake_config_file IN LISTS _cmake_config_files) 72 include("${_cmake_config_file}
") 74 unset(_cmake_config_file) 75 unset(_cmake_config_files) 77 # Cleanup temporary variables. 80 # Loop over all imported files and verify that they actually exist 81 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 82 if(CMAKE_VERSION VERSION_LESS "3.28
" 83 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 84 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 85 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 86 if(NOT EXISTS "${_cmake_file}
") 87 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 89 but this file does not exist. Possible reasons include: 90 * The file was deleted, renamed, or moved to another location. 91 * An install or uninstall procedure did not complete successfully. 92 * The installation package was faulty and contained 93 \"${CMAKE_CURRENT_LIST_FILE}\" 94 but not all the files it references. 100 unset("_cmake_import_check_files_for_${_cmake_target}
") 103 unset(_cmake_import_check_targets) 105 # Make sure the targets which have been exported in some other 107 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 108 foreach(_target "VTK::vtkpythonmodules
" ) 109 if(NOT TARGET "${_target}
" ) 110 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 114 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 115 if(CMAKE_FIND_PACKAGE_NAME) 116 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 117 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 119 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 122 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 124 # Commands beyond this point should not need to know the version. 125 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
