3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7 message(FATAL_ERROR "CMake >= 3.0.0 required")
10 cmake_policy(
VERSION 3.0.0...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParaView::PyvtkRemotingClientServerStreamPython ParaView::PyvtkPVVersioningPython ParaView::PyvtkPVVTKExtensionsCorePython ParaView::PyvtkRemotingCorePython ParaView::PyvtkRemotingServerManagerPython ParaView::PyvtkRemotingViewsPython ParaView::PyvtkRemotingViewsPythonPython ParaView::PyvtkRemotingServerManagerPythonPython ParaView::PyvtkRemotingMiscPython ParaView::PyvtkPVVTKExtensionsExtractionPython ParaView::PyvtkRemotingLivePython ParaView::PyvtkRemotingImportPython ParaView::PyvtkRemotingApplicationComponentsPython ParaView::PyvtkRemotingApplicationPython ParaView::PyvtkRemotingExportPython ParaView::PyvtkPVVTKExtensionsIOCorePython ParaView::PyvtkRemotingAnimationPython ParaView::PyvtkPVVTKExtensionsInteractionStylePython ParaView::PyvtkRemotingSettingsPython ParaView::PyvtkPVVTKExtensionsPointsPython ParaView::PyvtkPVVTKExtensionsIOSPCTHPython ParaView::PyvtkPVVTKExtensionsIOCGNSWriterPython ParaView::PyvtkPVVTKExtensionsIOParallelCGNSWriterPython ParaView::PyvtkPVVTKExtensionsIOImportPython ParaView::PyvtkPVVTKExtensionsIOImagePython ParaView::PyvtkPVVTKExtensionsIOGeneralPython ParaView::PyvtkPVVTKExtensionsIOExodusPython ParaView::PyvtkPVVTKExtensionsIOEnSightPython ParaView::PyvtkPVVTKExtensionsIOAMRPython ParaView::PyvtkPVVTKExtensionsFiltersStatisticsPython ParaView::PyvtkPVVTKExtensionsFiltersPythonPython ParaView::PyvtkPVVTKExtensionsFiltersGeneralPython ParaView::PyvtkPVVTKExtensionsFiltersParallelDIY2Python ParaView::PyvtkPVVTKExtensionsFiltersParallelPython ParaView::PyvtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::PyvtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::PyvtkPVVTKExtensionsFiltersRenderingPython ParaView::PyvtkPVVTKExtensionsMiscPython ParaView::PyvtkPVVTKExtensionsFiltersFlowPathsPython ParaView::PyvtkPVVTKExtensionsExtractionPythonPython ParaView::PyvtkPVVTKExtensionsAMRPython ParaView::PyvtkPVCatalystPython ParaView::PyvtkPVCatalystTestDriverPython ParaView::PyvtkPVPythonCatalystPython ParaView::PyvtkPVClientWebPython ParaView::PyvtkPVInSituPython ParaView::pvpythonmodules)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target ParaView::PyvtkRemotingClientServerStreamPython 59 add_library(ParaView::PyvtkRemotingClientServerStreamPython MODULE IMPORTED) 61 # Create imported target ParaView::PyvtkPVVersioningPython 62 add_library(ParaView::PyvtkPVVersioningPython MODULE IMPORTED) 64 # Create imported target ParaView::PyvtkPVVTKExtensionsCorePython 65 add_library(ParaView::PyvtkPVVTKExtensionsCorePython MODULE IMPORTED) 67 # Create imported target ParaView::PyvtkRemotingCorePython 68 add_library(ParaView::PyvtkRemotingCorePython MODULE IMPORTED) 70 # Create imported target ParaView::PyvtkRemotingServerManagerPython 71 add_library(ParaView::PyvtkRemotingServerManagerPython MODULE IMPORTED) 73 # Create imported target ParaView::PyvtkRemotingViewsPython 74 add_library(ParaView::PyvtkRemotingViewsPython MODULE IMPORTED) 76 # Create imported target ParaView::PyvtkRemotingViewsPythonPython 77 add_library(ParaView::PyvtkRemotingViewsPythonPython MODULE IMPORTED) 79 # Create imported target ParaView::PyvtkRemotingServerManagerPythonPython 80 add_library(ParaView::PyvtkRemotingServerManagerPythonPython MODULE IMPORTED) 82 # Create imported target ParaView::PyvtkRemotingMiscPython 83 add_library(ParaView::PyvtkRemotingMiscPython MODULE IMPORTED) 85 # Create imported target ParaView::PyvtkPVVTKExtensionsExtractionPython 86 add_library(ParaView::PyvtkPVVTKExtensionsExtractionPython MODULE IMPORTED) 88 # Create imported target ParaView::PyvtkRemotingLivePython 89 add_library(ParaView::PyvtkRemotingLivePython MODULE IMPORTED) 91 # Create imported target ParaView::PyvtkRemotingImportPython 92 add_library(ParaView::PyvtkRemotingImportPython MODULE IMPORTED) 94 # Create imported target ParaView::PyvtkRemotingApplicationComponentsPython 95 add_library(ParaView::PyvtkRemotingApplicationComponentsPython MODULE IMPORTED) 97 # Create imported target ParaView::PyvtkRemotingApplicationPython 98 add_library(ParaView::PyvtkRemotingApplicationPython MODULE IMPORTED) 100 # Create imported target ParaView::PyvtkRemotingExportPython 101 add_library(ParaView::PyvtkRemotingExportPython MODULE IMPORTED) 103 # Create imported target ParaView::PyvtkPVVTKExtensionsIOCorePython 104 add_library(ParaView::PyvtkPVVTKExtensionsIOCorePython MODULE IMPORTED) 106 # Create imported target ParaView::PyvtkRemotingAnimationPython 107 add_library(ParaView::PyvtkRemotingAnimationPython MODULE IMPORTED) 109 # Create imported target ParaView::PyvtkPVVTKExtensionsInteractionStylePython 110 add_library(ParaView::PyvtkPVVTKExtensionsInteractionStylePython MODULE IMPORTED) 112 # Create imported target ParaView::PyvtkRemotingSettingsPython 113 add_library(ParaView::PyvtkRemotingSettingsPython MODULE IMPORTED) 115 # Create imported target ParaView::PyvtkPVVTKExtensionsPointsPython 116 add_library(ParaView::PyvtkPVVTKExtensionsPointsPython MODULE IMPORTED) 118 # Create imported target ParaView::PyvtkPVVTKExtensionsIOSPCTHPython 119 add_library(ParaView::PyvtkPVVTKExtensionsIOSPCTHPython MODULE IMPORTED) 121 # Create imported target ParaView::PyvtkPVVTKExtensionsIOCGNSWriterPython 122 add_library(ParaView::PyvtkPVVTKExtensionsIOCGNSWriterPython MODULE IMPORTED) 124 # Create imported target ParaView::PyvtkPVVTKExtensionsIOParallelCGNSWriterPython 125 add_library(ParaView::PyvtkPVVTKExtensionsIOParallelCGNSWriterPython MODULE IMPORTED) 127 # Create imported target ParaView::PyvtkPVVTKExtensionsIOImportPython 128 add_library(ParaView::PyvtkPVVTKExtensionsIOImportPython MODULE IMPORTED) 130 # Create imported target ParaView::PyvtkPVVTKExtensionsIOImagePython 131 add_library(ParaView::PyvtkPVVTKExtensionsIOImagePython MODULE IMPORTED) 133 # Create imported target ParaView::PyvtkPVVTKExtensionsIOGeneralPython 134 add_library(ParaView::PyvtkPVVTKExtensionsIOGeneralPython MODULE IMPORTED) 136 # Create imported target ParaView::PyvtkPVVTKExtensionsIOExodusPython 137 add_library(ParaView::PyvtkPVVTKExtensionsIOExodusPython MODULE IMPORTED) 139 # Create imported target ParaView::PyvtkPVVTKExtensionsIOEnSightPython 140 add_library(ParaView::PyvtkPVVTKExtensionsIOEnSightPython MODULE IMPORTED) 142 # Create imported target ParaView::PyvtkPVVTKExtensionsIOAMRPython 143 add_library(ParaView::PyvtkPVVTKExtensionsIOAMRPython MODULE IMPORTED) 145 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersStatisticsPython 146 add_library(ParaView::PyvtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED) 148 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersPythonPython 149 add_library(ParaView::PyvtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED) 151 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersGeneralPython 152 add_library(ParaView::PyvtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED) 154 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersParallelDIY2Python 155 add_library(ParaView::PyvtkPVVTKExtensionsFiltersParallelDIY2Python MODULE IMPORTED) 157 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersParallelPython 158 add_library(ParaView::PyvtkPVVTKExtensionsFiltersParallelPython MODULE IMPORTED) 160 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersMaterialInterfacePython 161 add_library(ParaView::PyvtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED) 163 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersGeneralMPIPython 164 add_library(ParaView::PyvtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED) 166 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersRenderingPython 167 add_library(ParaView::PyvtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED) 169 # Create imported target ParaView::PyvtkPVVTKExtensionsMiscPython 170 add_library(ParaView::PyvtkPVVTKExtensionsMiscPython MODULE IMPORTED) 172 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersFlowPathsPython 173 add_library(ParaView::PyvtkPVVTKExtensionsFiltersFlowPathsPython MODULE IMPORTED) 175 # Create imported target ParaView::PyvtkPVVTKExtensionsExtractionPythonPython 176 add_library(ParaView::PyvtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED) 178 # Create imported target ParaView::PyvtkPVVTKExtensionsAMRPython 179 add_library(ParaView::PyvtkPVVTKExtensionsAMRPython MODULE IMPORTED) 181 # Create imported target ParaView::PyvtkPVCatalystPython 182 add_library(ParaView::PyvtkPVCatalystPython MODULE IMPORTED) 184 # Create imported target ParaView::PyvtkPVCatalystTestDriverPython 185 add_library(ParaView::PyvtkPVCatalystTestDriverPython MODULE IMPORTED) 187 # Create imported target ParaView::PyvtkPVPythonCatalystPython 188 add_library(ParaView::PyvtkPVPythonCatalystPython MODULE IMPORTED) 190 # Create imported target ParaView::PyvtkPVClientWebPython 191 add_library(ParaView::PyvtkPVClientWebPython MODULE IMPORTED) 193 # Create imported target ParaView::PyvtkPVInSituPython 194 add_library(ParaView::PyvtkPVInSituPython MODULE IMPORTED) 196 # Create imported target ParaView::pvpythonmodules 197 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED) 199 set_target_properties(ParaView::pvpythonmodules PROPERTIES 200 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/pvpythonmodules
" 201 INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules
" 204 # Load information for each installed configuration. 205 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/
ParaViewPython-targets-*.cmake
") 206 foreach(_cmake_config_file IN LISTS _cmake_config_files) 207 include("${_cmake_config_file}
") 209 unset(_cmake_config_file) 210 unset(_cmake_config_files) 212 # Cleanup temporary variables. 215 # Loop over all imported files and verify that they actually exist 216 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 217 if(CMAKE_VERSION VERSION_LESS "3.28
" 218 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 219 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 220 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 221 if(NOT EXISTS "${_cmake_file}
") 222 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 224 but this file does not exist. Possible reasons include: 225 * The file was deleted, renamed, or moved to another location. 226 * An install or uninstall procedure did not complete successfully. 227 * The installation package was faulty and contained 228 \"${CMAKE_CURRENT_LIST_FILE}\" 229 but not all the files it references. 235 unset("_cmake_import_check_files_for_${_cmake_target}
") 238 unset(_cmake_import_check_targets) 240 # Make sure the targets which have been exported in some other 242 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 243 foreach(_target "VTK::vtkpythonmodules
" ) 244 if(NOT TARGET "${_target}
" ) 245 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 249 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 250 if(CMAKE_FIND_PACKAGE_NAME) 251 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 252 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 254 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 257 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 259 # Commands beyond this point should not need to know the version. 260 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
