1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
47 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.6.2" 48 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.1" 50 if(EXISTS
"${file}" AND
51 NOT IS_SYMLINK
"${file}")
54 RPATH
"\$ORIGIN:/usr/lib64/openmpi/lib")
" TYPE SHARED_LIBRARY FILES 58 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.6.2
" 59 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.1
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.6.2
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.1
" 65 if(EXISTS "${file}
") 69 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 70 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 71 if(CMAKE_INSTALL_DO_STRIP) 72 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 79 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPhasta-pv6.2.so
" OR NOT CMAKE_INSTALL_COMPONENT) 85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta/PhastaAdaptor.h
") 89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta/vtkPVAdaptorsPhastaModule.h
") 93 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta/vtkPVAdaptorsPhasta.spdx
