0009989ParaViewBugpublic2009-12-01 21:412011-09-01 13:31
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeveritycrashReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.6Fixed in Version3.12
Summary0009989: pvblot: crashes opening cth dataset
DescriptionParaView trunk from a few weeks ago, Linux, local server.
pvblot. Input file: Dave's small CTH dataset, group a. (Utkarsh or Berk should have this, if not, ask me and I can get it for you.) It will be spcta_a.1,2,3 and 4.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0018648)
2009-12-02 14:00
Ensuring that the SpyPlotReader is created for spcth files
correctly. Also adding spyplot extensions to the file open dialog.
/cvsroot/ParaView3/ParaView3/Plugins/pvblot/PVBlotPluginActions.cxx,v <-- Plugins/pvblot/PVBlotPluginActions.cxx
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/Plugins/pvblot/blotish.py,v <-- Plugins/pvblot/blotish.py
new revision: 1.4; previous revision: 1.3
(0018860)
Alan Scott (manager)
2009-12-14 12:56
This hangs with Dave K.'s small cth dataset. This needs to be fixed.
Alan
(0018866)
2009-12-14 13:28
build error on my part. Changing to resolved until I can get a good build.
(0018917)
2009-12-16 09:53
Fixed BUG 0009989 by adding method to vtkSMReaderFactory to test
CanReadFile() to test if a reader can read a file and then using it in
blotish.py to test if the file is a spcth file. This removed the dependence of
names of the file.
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMReaderFactory.h,v <-- Servers/ServerManager/vtkSMReaderFactory.h
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMReaderFactory.cxx,v <-- Servers/ServerManager/vtkSMReaderFactory.cxx
(0018931)
2009-12-16 17:11
This seems to be working now. Thanks!
* When the spyplot reader starts, it also starts filter ExtractCTHParts. Is this by design, or is this a bug?
* There are masses of error prints that are written out. Please turn them off. When opening Dave's CTH files, I get the following:
spydatafile
setting Current file name /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.0
buffer1 == /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.-100
buffer2 == /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.100
buffer3 == /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.0
buffer3 == /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.1
buffer3 == /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.2
buffer3 == /ascldap/users/wascott/data/daveCTH/cth-small/spcta_a.3
updating meta...
spydatafile
updating meta...
spydatafile
Not setting much else
spydatafile
updating meta...
spydatafile
spydatafile
updating meta...
spydatafile
(0018944)
2009-12-17 17:56
Tested local client.
As far as the print statements, Utkarsh has fixed it.
We will keep the CTHParts filter in place, unless user decides otherwise.
 Issue History
2009-12-01 21:41 Alan Scott New Issue
2009-12-02 13:59 Utkarsh Ayachit Status backlog => tabled
2009-12-02 13:59 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2009-12-02 14:00 Utkarsh Ayachit Note Added: 0018648
2009-12-02 14:00 Utkarsh Ayachit Status tabled => @80@
2009-12-02 14:00 Utkarsh Ayachit Fixed in Version => Development
2009-12-02 14:00 Utkarsh Ayachit Resolution open => fixed
2009-12-14 12:56 Alan Scott Note Added: 0018860
2009-12-14 12:56 Alan Scott Status @80@ => @20@
2009-12-14 12:56 Alan Scott Resolution fixed => reopened
2009-12-14 13:28 Alan Scott Note Added: 0018866
2009-12-14 13:28 Alan Scott Status @20@ => @80@
2009-12-14 13:28 Alan Scott Resolution reopened => fixed
2009-12-16 09:52 Utkarsh Ayachit Status @80@ => tabled
2009-12-16 09:53 Utkarsh Ayachit Note Added: 0018917
2009-12-16 09:53 Utkarsh Ayachit Status tabled => @80@
2009-12-16 17:11 Alan Scott Note Added: 0018931
2009-12-16 17:11 Alan Scott Status @80@ => @20@
2009-12-16 17:11 Alan Scott Resolution fixed => reopened
2009-12-17 17:56 Alan Scott Note Added: 0018944
2009-12-17 17:56 Alan Scott Status @20@ => closed
2009-12-17 17:56 Alan Scott Resolution reopened => fixed
2011-09-01 13:31 Utkarsh Ayachit Fixed in Version Development => 3.12
