0009967 | ParaView | Bug | public | 2009-11-24 22:41 | 2010-01-21 17:18 | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0009967: Multiple lsdyna files don't show up properly in file/open | ||||||||
Description | Multiple lsdyna files don't show up properly in file/open. What should happen is that you see a file named d3plot in the open window. What you have to do is select "Files of type", then *.*. This needs to be fixed. | ||||||||
(0019242) Utkarsh Ayachit (administrator) 2010-01-21 12:48 |
Added support for 'filename_patterns" attribute to specify the filename wildcard patterns that match the this reader which is used in addition to extension testing for picking readers. Added filename_pattern "d3plot" for the LSDyna reader. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/readers.xml,v <-- Servers/ServerManager/Resources/readers.xml new revision: 1.188; previous revision: 1.187 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMReaderFactory.cxx,v <-- Servers/ServerManager/vtkSMReaderFactory.cxx new revision: 1.3; previous revision: 1.2 |
(0019248) Alan Scott (manager) 2010-01-21 17:18 |
Tested local server, XP, trunk. |
2009-11-24 22:41 | Alan Scott | New Issue | |
2010-01-21 12:48 | Utkarsh Ayachit | Note Added: 0019242 | |
2010-01-21 12:48 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-01-21 12:48 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-01-21 12:48 | Utkarsh Ayachit | Resolution | open => fixed |
2010-01-21 12:48 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-01-21 17:18 | Alan Scott | Note Added: 0019248 | |
2010-01-21 17:18 | Alan Scott | Status | @80@ => closed |
