0009919 | ParaView | Bug | public | 2009-11-18 14:48 | 2010-07-07 16:46 | ||||
Assigned To | Zhanping Liu | ||||||||
Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
Summary | 0009919: Contour precision is wrong | ||||||||
Description | ParaView 3.6.2, XP, local server. * Source/ Wavelet. Apply. * Contour filter. Change default to 157.12345. * <CR>. Note that the precision changes back to 3 digits. This is wrong. Big picture - any entry box should allow any amount of precision. If there are other filters with this code/problem, they also should be fixed. | ||||||||
(0020546) Zhanping Liu (developer) 2010-05-04 15:19 |
Changes were made to pqScalarSetModel.cxx, committed to the Git repository. |
(0020553) Alan Scott (manager) 2010-05-04 16:54 |
Tested local server, trunk, Windows. |
(0021291) Utkarsh Ayachit (administrator) 2010-07-07 16:46 edited on: 2010-07-07 16:47 |
moved to release branch. commit daa82660cab7aca3fef044dfc42131a3113b37a0 Author: Zhanping Liu <zhanping.liu@kitware.com> Date: Fri Apr 30 14:31:37 2010 -0400 increase the visual precision of floating-point values in widgets bug 9919. commit 6fe43eea287841d1970a72638399fd8700f53bd1 Author: Zhanping Liu <zhanping.liu@kitware.com> Date: Fri Apr 30 12:43:06 2010 -0400 Increase the visual precision of floating-point values in widgets. This fix to bug 9919 allows the user to see a sufficient number of digits (numerical precision), e.g., those shown in the contour filter's widget. |
2009-11-18 14:48 | Alan Scott | New Issue | |
2010-04-16 02:10 | Utkarsh Ayachit | Target Version | 3.8 => 3.8.2 |
2010-04-19 17:33 | Utkarsh Ayachit | Status | backlog => tabled |
2010-04-19 17:33 | Utkarsh Ayachit | Assigned To | => Zhanping Liu |
2010-05-04 15:19 | Zhanping Liu | Note Added: 0020546 | |
2010-05-04 15:19 | Zhanping Liu | Status | tabled => @80@ |
2010-05-04 16:54 | Alan Scott | Note Added: 0020553 | |
2010-05-04 16:54 | Alan Scott | Status | @80@ => closed |
2010-05-04 16:54 | Alan Scott | Resolution | open => fixed |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | => Development |
2010-07-07 10:57 | Utkarsh Ayachit | Note Added: 0021281 | |
2010-07-07 16:46 | Utkarsh Ayachit | Note Added: 0021291 | |
2010-07-07 16:46 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
2010-07-07 16:47 | Utkarsh Ayachit | Note Edited: 0021291 | |
2010-07-07 16:47 | Utkarsh Ayachit | Note Deleted: 0021281 |
