0000099 | VTK | (No Category) | public | 2003-07-25 11:15 | 2003-09-23 16:28 | ||||
Reporter | Bill Hoffman | ||||||||
Assigned To | Brad King | ||||||||
Summary | 0000099: cmake should test for ansi stream header files | ||||||||
Description | CMake should be used to test for ansi header files. Right now, it uses them for gcc and devenv but users can turn on VTK_USE_ANSI_STDLIB by hand and break code. The HP supports ANSI, but does not have the new header files. This should be a cmake test. | ||||||||
(0000119) Brad King (developer) 2003-09-23 16:28 |
The top-level CMakeLists.txt file in VTK now test for the existence of non-ANSI and ANSI stream headers separately. The VTK_USE_ANSI_STDLIB option is only provided if both headers are available. |
