0000097 | VTK | (No Category) | public | 2003-07-25 08:56 | 2016-08-12 09:53 | ||||
Reporter | Dennis Jen | ||||||||
Assigned To | Dave DeMarle | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0000097: Window Size in vtkCanvas Does Not Affect Interactor | ||||||||
Description | There is a bug in vtkCanvas (line 31), where the interactor is initially set to 200 by 200. Consequenty, when the window is initially set to be larger than 200 x 200, the screen coordinates of the mouse position returned by the interactor are off by 200. Calling resize on a vtkPanel does not result in the correct size in the interactor. However, manually (expanding/shrinking the window with the mouse) resizing the window fixes this problem. The work around that I've found is to set the interactor of the render window to the size of my window when I first create my window. | ||||||||
(0030956) Jean-Christophe Fillion-Robin (manager) 2013-06-05 17:58 |
Does the problem still occur with VTK 5.10 ? VTK 6 ? |
(0031224) Dave DeMarle (administrator) 2013-07-22 19:22 |
If the bug persists in 6.0.0, please reopen. |
(0036695) Kitware Robot (administrator) 2016-08-12 09:53 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2007-08-04 16:11 | Berk Geveci | Assigned To | Sean McBride => |
2007-08-04 16:11 | Berk Geveci | Severity | major => minor |
2007-08-04 16:11 | Berk Geveci | Status | @80@ => backlog |
2007-08-04 16:11 | Berk Geveci | Resolution | won't fix => open |
2007-08-04 16:11 | Berk Geveci | Summary | Goodsite => Window Size in vtkCanvas Does Not Affect Interactor |
2007-08-04 16:12 | Berk Geveci | Note Deleted: 0008211 | |
2007-08-04 16:12 | Berk Geveci | Project | @4@ => VTK |
2008-08-29 17:36 | David Cole | Status | backlog => tabled |
2008-08-29 17:36 | David Cole | Assigned To | => David Cole |
2011-01-19 09:49 | David Cole | Assigned To | David Cole => |
2013-06-05 17:58 | Jean-Christophe Fillion-Robin | Note Added: 0030956 | |
2013-07-22 19:22 | Dave DeMarle | Note Added: 0031224 | |
2013-07-22 19:22 | Dave DeMarle | Status | backlog => expired |
2013-07-22 19:22 | Dave DeMarle | Assigned To | => Dave DeMarle |
2016-08-12 09:53 | Kitware Robot | Note Added: 0036695 | |
2016-08-12 09:53 | Kitware Robot | Status | expired => closed |
2016-08-12 09:53 | Kitware Robot | Resolution | open => moved |
