0009650 | ParaView | Bug | public | 2009-10-02 16:59 | 2009-12-16 19:30 | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0009650: Stream tracer enabled for two inputs | ||||||||
Description | Stream tracer is enabled for two inputs, but should not be. ParaView 3.6.2, local server, XP. Open disk_out_ref.exo. Apply. Open can.exo. Apply. <CTRL> select disk_out_ref.exo, making both input files highlighted. Filters/Alphabetical. <<Bug>> Note that you can now use the stream trace filter on both inputs. Doesn't make sense, and it does bad things. | ||||||||
(0018736) Utkarsh Ayachit (administrator) 2009-12-09 10:36 |
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.380; previous revision: 1.379 |
(0018939) Alan Scott (manager) 2009-12-16 19:30 |
Tested local server. |
2009-10-02 16:59 | Alan Scott | New Issue | |
2009-12-09 10:36 | Utkarsh Ayachit | Note Added: 0018736 | |
2009-12-09 10:36 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-12-09 10:36 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2009-12-09 10:36 | Utkarsh Ayachit | Resolution | open => fixed |
2009-12-09 10:36 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-16 19:30 | Alan Scott | Note Added: 0018939 | |
2009-12-16 19:30 | Alan Scott | Status | @80@ => closed |
