0009642 | VTK | (No Category) | public | 2009-10-02 05:45 | 2016-08-12 09:55 | ||||
Reporter | U. Mennel | ||||||||
Summary | 0009642: coincident topology resolution methods in vtkMapper should not be static | ||||||||
Description | I am wondering why the coincident topology resolution methods in vtkMapper are implemented as static methods. With the new vtkPainter based rendering it would be possible to render surfaces with different polygon offsets to enable overlapping surfaces. Therefore, each vtkMapper must have its own coincident topology resolution settings. | ||||||||
(0018229) dbarbier (reporter) 2009-10-25 07:09 |
There is a patch attached to bug 7294 |
(0018289) U. Mennel (reporter) 2009-10-29 19:25 |
I see. So this issue is redundant and can be closed. |
(0037107) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-10-02 05:45 | U. Mennel | New Issue | |
2009-10-25 07:09 | dbarbier | Note Added: 0018229 | |
2009-10-29 19:25 | U. Mennel | Note Added: 0018289 | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037107 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
