0009636 | VTK | (No Category) | public | 2009-10-01 22:43 | 2016-08-12 09:55 | ||||
Reporter | suzuki toshiya | ||||||||
Summary | 0009636: CMakeList.txt lacks the directories to be scanned for system FreeType2 | ||||||||
Description | VTK CMake has a feature to use FreeType2 library in the system itself, instead of FreeType2 included in VTK source tree. However, some CMakeList.txt lacks the directories for system FreeType2 headers. In most GNU/Linux systems that FreeType2 is installed into /usr, the lack causes no problem because /usr/include is scanned by default. However if FreeType2 is installed into special directories (e.g. Apple installs FreeType2 as a part of X11 system, so /usr/X11R6/include/freetype2 etc should be scanned). Attached patch modifies a few CMakeFile.txt to include FREETYPE_INCLUDE_DIR_freetype2 and FREETYPE_INCLUDE_DIR_ft2build. | ||||||||
Attached Files | VTK-CVS_sys-freetype.diff [^] (1,852 bytes) 2009-10-01 22:43 [Show Content] | ||||||||
(0037105) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-10-01 22:43 | suzuki toshiya | New Issue | |
2009-10-01 22:43 | suzuki toshiya | File Added: VTK-CVS_sys-freetype.diff | |
2010-11-30 22:53 | David Partyka | Assigned To | => David Partyka |
2010-11-30 22:53 | David Partyka | Status | backlog => tabled |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037105 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
