0009582 | ParaView | Bug | public | 2009-09-22 03:34 | 2009-09-23 11:22 | ||||
Reporter | jhgoebbert | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Product Version | 3.6 | ||||||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0009582: XDMF with GeometryType="X_Y_Z" and Topology="3dRectMesh" fails | ||||||||
Description | The following example segfaults - but it should not. <?xml version="1.0" ?> <!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []> <Xdmf Version="2.0"> <Domain Name="test_geom"> <Grid Name="SpatialCollection" GridType="Collection" CollectionType="Spatial"> <Grid Name="1-1-1_t0.0" Type="Uniform"> <Topology TopologyType="3DRectMesh" NumberOfElements="512 512 512"> </Topology> <Geometry GeometryType="X_Y_Z"> <DataItem Name="X" Format="HDF" NumberType="Float" Precision="8" Dimensions="512"> test_geom.h5:/coordx </DataItem> <DataItem Name="Y" Format="HDF" NumberType="Float" Precision="8" Dimensions="512"> test_geom.h5:/coordy </DataItem> <DataItem Name="Z" Format="HDF" NumberType="Float" Precision="8" Dimensions="512"> test_geom.h5:/coordz </DataItem> </Geometry> </Grid> </Grid> </Domain> </Xdmf> | ||||||||
Additional Information | I checked the same test-case without hdf5 but simple xml-dataitem => same segfault :( | ||||||||
Attached Files | test_geom.xmf [^] (1,330 bytes) 2009-09-22 03:34 test_geom.h5 [^] (15,136 bytes) 2009-09-22 03:35 | ||||||||
(0017702) Utkarsh Ayachit (administrator) 2009-09-22 10:39 |
Complain when RectMesh does not have the correct type of geometry instead of segfaulting. Also added support for geometry types VXVY and DXDY. /cvsroot/ParaView3/ParaView3/Utilities/Xdmf2/vtk/vtkXdmfHeavyData.cxx,v <-- Utilities/Xdmf2/vtk/vtkXdmfHeavyData.cxx new revision: 1.11; previous revision: 1.10 |
(0017723) Alan Scott (manager) 2009-09-22 22:15 |
Why are you writing to the calling xterm, shouldn't this output be sent to the output window? If a user is on XP, and is running ParaView from the GUI, she will never see the error. How about sending to the output window? |
(0017725) jhgoebbert (reporter) 2009-09-23 04:27 |
What do you mean with "Complain when RectMesh does not have the correct type of geometry instead of segfaulting."? Will 3DRectMesh not support geometry type X_Y_Z (if yes, why not)? |
(0017727) Utkarsh Ayachit (administrator) 2009-09-23 08:47 |
This reader is still under active development and hence all the error messages are still on xterm. A final step in finishing of the reader will be post these error messages as standard VTK errors. |
(0017728) Utkarsh Ayachit (administrator) 2009-09-23 08:53 |
Rectilinear mesh will not support X_Y_Z. You actually don't need X_Y_Z for rectilinear meshes, you are indeed specifying the locations along the 3 axes right, not the point coordinates for each point location. In that case you indeed want to use VXVYVZ. X_Y_Z is used for 3 arrays with point location for each and every point, in which case you'll need (512*512*512) elements in each of your arrays. For rectilinear grids, you don't do that. You simply specify the locations along each axis, hence you only need 512 elements in each array -- which is what you are doing and that should be denoted using geometry type VXVYVZ. In your example, just change to GeometryType="VXVYVZ" and it loads just fine in ParaView. |
(0017733) Alan Scott (manager) 2009-09-23 11:22 |
Tested, code doesn't seg fault - but rather complains as expected. Tested local server, trunk. |
2009-09-22 03:34 | jhgoebbert | New Issue | |
2009-09-22 03:34 | jhgoebbert | File Added: test_geom.xmf | |
2009-09-22 03:35 | jhgoebbert | File Added: test_geom.h5 | |
2009-09-22 10:39 | Utkarsh Ayachit | Status | backlog => tabled |
2009-09-22 10:39 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-09-22 10:39 | Utkarsh Ayachit | Note Added: 0017702 | |
2009-09-22 10:39 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-09-22 10:39 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2009-09-22 10:39 | Utkarsh Ayachit | Resolution | open => fixed |
2009-09-22 22:15 | Alan Scott | Note Added: 0017723 | |
2009-09-22 22:15 | Alan Scott | Status | @80@ => @20@ |
2009-09-22 22:15 | Alan Scott | Resolution | fixed => reopened |
2009-09-23 04:27 | jhgoebbert | Note Added: 0017725 | |
2009-09-23 08:47 | Utkarsh Ayachit | Note Added: 0017727 | |
2009-09-23 08:53 | Utkarsh Ayachit | Note Added: 0017728 | |
2009-09-23 08:53 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-09-23 08:53 | Utkarsh Ayachit | Resolution | reopened => fixed |
2009-09-23 11:22 | Alan Scott | Note Added: 0017733 | |
2009-09-23 11:22 | Alan Scott | Status | @80@ => closed |
