Attached Files | vtkConvexPointSet-CellBoundary.diff [^] (4,052 bytes) 2009-09-16 07:30 [Show Content] [Hide Content]Index: VTK/Filtering/vtkConvexPointSet.cxx
RCS file: /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkConvexPointSet.cxx,v
retrieving revision 1.6
diff -u -r1.6 vtkConvexPointSet.cxx
--- VTK/Filtering/vtkConvexPointSet.cxx 4 Aug 2009 16:57:05 -0000 1.6
+++ VTK/Filtering/vtkConvexPointSet.cxx 16 Sep 2009 11:25:11 -0000
@@ -201,58 +201,15 @@
int vtkConvexPointSet::CellBoundary(int subId, double pcoords[3],
vtkIdList *pts)
- int i, status, returnStatus=(-1);
- double p[3], x[3], dist2, minDist2=VTK_DOUBLE_MAX, pMin[3];
- double closest[3], pc[3];
- double weights[4];
- // Get the current global coordinate
- this->EvaluateLocation(subId, pcoords, p, weights);
+ vtkIdType ptId;
- // Find the closest point
- vtkIdType numPts = this->PointIds->GetNumberOfIds();
- for (i=0; i < numPts; i++)
+ for (int j=0; j<4; j++)
- this->Points->GetPoint(i, x);
- dist2 = vtkMath::Distance2BetweenPoints(x,p);
- if ( dist2 < minDist2 )
- pMin[0] = x[0];
- pMin[1] = x[1];
- pMin[2] = x[2];
- minDist2 = dist2;
- // Get the faces connected to the point, find the closest face
- this->BoundaryTris->Reset();
- this->Triangulator->AddTriangles(this->BoundaryTris);
- vtkIdType npts, *tpts=0;
- for ( minDist2=VTK_DOUBLE_MAX, this->BoundaryTris->InitTraversal();
- this->BoundaryTris->GetNextCell(npts,tpts); )
- this->Triangle->PointIds->SetId(0,tpts[0]);
- this->Triangle->PointIds->SetId(1,tpts[1]);
- this->Triangle->PointIds->SetId(2,tpts[2]);
- this->Triangle->Points->SetPoint(0,this->Points->GetPoint(tpts[0]));
- this->Triangle->Points->SetPoint(1,this->Points->GetPoint(tpts[1]));
- this->Triangle->Points->SetPoint(2,this->Points->GetPoint(tpts[2]));
- status = this->Triangle->
- EvaluatePosition(pMin, closest, subId, pc, dist2, weights);
- if ( status != -1 && dist2 < minDist2)
- returnStatus = 1;
- pts->SetNumberOfIds(3);
- pts->SetId(0,this->PointIds->GetId(tpts[0]));
- pts->SetId(1,this->PointIds->GetId(tpts[1]));
- pts->SetId(2,this->PointIds->GetId(tpts[2]));
- minDist2 = dist2;
+ ptId = this->PointIds->GetId(this->TetraIds->GetId(4*subId+j));
+ this->Tetra->PointIds->SetId(j,ptId);
+ this->Tetra->Points->SetPoint(j,this->TetraPoints->GetPoint(4*subId+j));
- return returnStatus;
+ return this->Tetra->CellBoundary(subId, pcoords, pts);
@@ -262,12 +219,12 @@
double& minDist2, double *weights)
double pc[3], dist2;
- int ignoreId, i, j, returnStatus=0, status;
+ int ignoreId, i, j, k, returnStatus=0, status;
double tempWeights[4];
double closest[3];
vtkIdType ptId;
int numTets = this->TetraIds->GetNumberOfIds() / 4;
+ int numPoints = this->GetNumberOfPoints();
for (minDist2=VTK_DOUBLE_MAX, i=0; i<numTets; i++)
@@ -280,18 +237,24 @@
status = this->Tetra->EvaluatePosition(x,closest,ignoreId,pc,dist2,
tempWeights);
if ( status != -1 && dist2 < minDist2 )
+ // initialize weights, since only the weights for the found tetrahedron are set below
+ for(k = 0; k < numPoints; ++k)
+ weights[k] = 0.0;
returnStatus = status;
minDist2 = dist2;
subId = i;
pcoords[0] = pc[0];
pcoords[1] = pc[1];
pcoords[2] = pc[2];
- weights[0] = tempWeights[0];
- weights[1] = tempWeights[1];
- weights[2] = tempWeights[2];
- weights[3] = tempWeights[3];
+ weights[this->TetraIds->GetId(4*i)] = tempWeights[0];
+ weights[this->TetraIds->GetId(4*i+1)] = tempWeights[1];
+ weights[this->TetraIds->GetId(4*i+2)] = tempWeights[2];
+ weights[this->TetraIds->GetId(4*i+3)] = tempWeights[3];
