0009542 | VTK | (No Category) | public | 2009-09-15 10:44 | 2016-08-12 09:55 | ||||
Reporter | David Doria | ||||||||
Summary | 0009542: vtkTransformPolyDataFilter changes unsigned chars to floats | ||||||||
Description | If you have a polydata and you apply a vtkTransform to it with vtkTransformPolyDataFilter, it changes vtkUnsignedCharArray's into vtkFloatArray's. This is problematic particularly in Paraview when you are displaying colors from an UnsignedChar array, then you transform the polydata - the colors no longer work in paraview as they are now floats. | ||||||||
(0037100) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-09-15 10:44 | David Doria | New Issue | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037100 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
