0009493 | VTK | (No Category) | public | 2009-09-04 15:40 | 2016-08-12 09:55 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0009493: verdict tri radius ratio not implemented in v_tri_quality() | ||||||||
Description | One should be able to do TriMetricVals values; v_tri_quality(3, coords, V_TRI_RADIUS_RATIO, &values); and get the results. But 0 is returned. | ||||||||
(0017357) Philippe Pebay (developer) 2009-09-09 13:14 |
Should be fixed. Please verify that it works with your new application and let me know if it does not. Thanks. |
(0037097) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-09-04 15:40 | Clinton Stimpson | New Issue | |
2009-09-04 15:40 | Clinton Stimpson | Status | backlog => tabled |
2009-09-04 15:40 | Clinton Stimpson | Assigned To | => Philippe Pebay |
2009-09-08 20:48 | Philippe Pebay | Status | tabled => @30@ |
2009-09-09 13:15 | Philippe Pebay | Note Added: 0017357 | |
2009-09-09 13:15 | Philippe Pebay | Status | @30@ => tabled |
2009-09-09 13:15 | Philippe Pebay | Resolution | open => fixed |
2009-09-09 13:15 | Philippe Pebay | Assigned To | Philippe Pebay => Clinton Stimpson |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037097 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | fixed => moved |
