0009473 | ParaView | Feature | public | 2009-09-01 10:51 | 2016-08-12 09:57 | ||||
Reporter | Stephane P | ||||||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0009473: adding frames to an animation | ||||||||
Description | give the possibility to expand an existing animation : in Sequence mode, it would be nice to have the possibility to add frames at the beginning or at the end of the animation. The result would be to add new frames, and to modify the Start and End time of all existing animation cues. For instance, if the animation is currently 100 frames long, adding 100 frames at the end would give an animation with 200 frames, and all start and end times of the existing animation cues would be divided by 2. | ||||||||
Project | ParaViS | ||||||||
(0037687) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-09-01 10:51 | Stephane P | New Issue | |
2010-06-15 09:06 | Utkarsh Ayachit | Target Version | => 3.10 |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037687 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
