0009459 | VTK | Bug | public | 2009-08-31 00:42 | 2014-10-01 21:34 | ||||
Reporter | Ayman W. Habib | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Summary | 0009459: Bug in picking objects arranged as an assembly | ||||||||
Description | Quoting "Eran Guendelman" back in 2007, using VTK 5.0.3 I'm finding in my program that even when I call SetVisibility(0) and SetPickable(0) on vtkActors in my scene, the vtkPropPicker is incorrectly allowing them to be picked. I traced through the VTK code and believe I found the bug. Here's basically what's happening. Say my scene is: A -> B -> C -> D A: top level scene assembly B: an assembly which is a part of A (e.g. a model in the scene) C and D: vtkActors which are part of assembly B (e.g. bodies in my model) So now suppose I hide body C (SetVisibility(0), and also SetPickable(0) for good measure although I don't think that's necessary under usual circumstances). vtkPropPicker::Pick() calls vtkRenderer::PickRender() down the line, which does the following: (1) Goes through all the top-level vtkProps in the scene. Namely A. It then adds A to a pickFrom list. (2) A cullPicker (of type vtkPicker) is created to execute a pick against bounding boxes, to cull the bodies that will be rendered by the underlying DevicePickRender(). vtkPicker::Pick goes through each vtkProp in the pickFrom list (namely A), and goes through all paths of that prop (namely A->B->C and A->B->D). It omits any paths whose leaf node is not visible (so it omits A->B->C but intersects against A->B->D). In the situation where we do intersect D's bounding box, the top-level vtkProp is added to the vtkPicker's Prop3Ds list... ***i.e. A is added th the Prop3Ds list... NOT the leaf node D*** (3) back in vtkRenderer::PickRender(), it fills PathArray with *ALL* of the paths of all of the vtkProps in the Prop3Ds list. i.e. it fills PathArray with all of the paths of A, which are A->B->C and A->B->D. (THIS IS ALREADY BAD NEWS BECAUSE A->B->C IS BACK UNDER CONSIDERATION) (4) vtkOpenGLRenderer::DevicePickRender() is called, which calls vtkRenderer::PickGeometry(), which renders everything in the PathArray, and makes this comment: // We can render everything because if it was // not visible it would not have been put in the // list in the first place, and if it was allocated // no time (culled) it would have been removed from // the list So there's an obvious problem here. When an intersection with D was found, the top-level vtkProp A was added to the Prop3Ds list... and then *all* of the paths of A were intersected against by the device pick render step. Ignoring the fact that A->B->C is supposed to be invisible and not pickable! So is this a bug? And suggestions for getting around it? (Yes, I could make a flat scene graph and put C and D as top-level actors in the scene, but that's not a satisfactory solution). Thanks. | ||||||||
Project | TBD | ||||||||
(0032595) Joachim Pouderoux (developer) 2014-04-15 12:22 |
http://review.source.kitware.com/#/c/15150/ [^] |
(0033410) Sean McBride (developer) 2014-10-01 21:34 |
The gerrit change was merged. |
2009-08-31 00:42 | Ayman W. Habib | New Issue | |
2014-04-15 12:21 | Joachim Pouderoux | Project | => TBD |
2014-04-15 12:21 | Joachim Pouderoux | Type | => incorrect functionality |
2014-04-15 12:21 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-04-15 12:21 | Joachim Pouderoux | Status | expired => backlog |
2014-04-15 12:21 | Joachim Pouderoux | Resolution | open => fixed |
2014-04-15 12:21 | Joachim Pouderoux | Status | backlog => gerrit review |
2014-04-15 12:22 | Joachim Pouderoux | Note Added: 0032595 | |
2014-04-15 12:22 | Joachim Pouderoux | Category | (No Category) => Bug |
2014-10-01 21:34 | Sean McBride | Note Added: 0033410 | |
2014-10-01 21:34 | Sean McBride | Status | gerrit review => closed |
