0009425ParaViewBugpublic2009-08-14 18:262016-08-12 09:57
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0009425: Center lines don't line up properly against a plane
DescriptionI think this is a good example of a bug that I have been seeing on and off for a long time. This bug is also not a driver issue - I just tested it on thunderbird, which uses mesa.
Open file centerCrossBug (attached). Just rotate the 2d plane around, and the center cross will appear and disappear.
Replicated local server and remote server, hardware rendered and mesa rendered, Linux and XP. Trunk.
If possible, it would be nice to have this fixed for 3.6.2, but lets slip it to 3.8 if it is real hard.
TagsNo tags attached.
ProjectSandia
Topic Name
Type
-  Notes
(0017149)
Alan Scott (manager)
2009-08-17 12:52
File was not downloaded correctly. It is very close to the size limit. I will push it to Kitware manually.
(0036435)
2016-07-13 20:27
Just tested, and there are stitching issues. However, the line itself isn't coming or going.
(0037682)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
- Issue History
2009-08-14 18:26 Alan Scott New Issue
2009-08-17 12:52 Alan Scott Note Added: 0017149
2011-02-18 13:57 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2011-02-18 13:57 Utkarsh Ayachit Status backlog => tabled
2011-02-18 13:57 Utkarsh Ayachit Target Version 3.8 => 4.0
2011-09-01 10:56 Utkarsh Ayachit Project => Sandia
2016-07-13 20:27 Alan Scott Note Added: 0036435
2016-08-12 09:57 Kitware Robot Note Added: 0037682
2016-08-12 09:57 Kitware Robot Status backlog => closed
2016-08-12 09:57 Kitware Robot Resolution open => moved
Powered by Mantis Bugtracker
