0009423 | ParaView | Bug | public | 2009-08-14 17:37 | 2014-08-29 10:59 | ||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0009423: Python Trace generator doesn't do screenshots. | ||||||||
Description | * ParaView trunk, XP, local server. * Tools/ Python Shell/ Trace/ Start trace * Sources/ Cone. Apply. * File/ Save Screenshot. Save this somewhere. * Tools/ Python Shell/ Trace/ Stop trace * Tools/ Python Shell/ Trace/ Show trace <<Bug>> - there is no save screenshot. I tested this by saving the trace, and then executing it, and it did not save a file. <<Note - I didn't check animations, but I bet the same problem exists>> Since this is such basic functionality, it must be fixed for 3.6.2. | ||||||||
Tags | PythonTrace | ||||||||
Topic Name | refactor_python_tracing_2 | ||||||||
Relationships | ||||||
(0017278) Pat Marion (reporter) 2009-09-01 11:30 |
Saving a screenshot from the gui takes advantage of the Qt based view manager class. The gui lets you capture all the views together. The current pvpython api only allows you to save a single render view. The gui lets you specify a size [x, y], but from python you must resize the render window to get the desired aspect ratio and then you can pass a magnification argument to save screenshot. I could set it up so that trace only captures the save screenshot event if the user has chosen "Save only selected view" in the gui (and the selected view is a 3D render view). What do you think, Alan? |
(0017288) Alan Scott (manager) 2009-09-01 16:34 |
I think that it would be OK short term, and possibly long term, to only "save only selected view". Then, the user can change the selected view, and do another "save only selected view". Thus, a user could write out each and every view serially. I think that limiting output to only 3D render is unacceptably restrictive. Users are using XY Plot View more and more, as well as 2D View. |
(0017291) Berk Geveci (administrator) 2009-09-01 20:58 |
I think that this should wait until 3.8 when we have proper multi-view/chart-view management in the server manager. Any solution we come up with now is going to be a hack and will be thrown away in 3.8. There is enough documentation here and there that explain how you can capture a 3D window from Python. For capturing the chart windows, the users will have to wait until 3.8. |
(0019935) Utkarsh Ayachit (administrator) 2010-03-17 10:30 |
Pat has committed a basic version to capture screenshots in trace. Deferring the extended screenshot tracing to 4.0. |
(0029506) Alan Scott (manager) 2012-10-24 17:20 |
Making sure this does not expire. |
(0032999) Utkarsh Ayachit (administrator) 2014-07-09 21:34 |
Developer note: Current version generates the following trace: =========================================================================== #### import the simple module from the paraview from paraview.simple import * #### disable automatic camera reset on 'Show' paraview.simple._DisableFirstRenderCameraReset() # create a new 'Cone' cone0 = Cone() # get active view renderView0 = GetActiveViewOrCreate('RenderView') # uncomment following to set a specific view size # renderView0.ViewSize = [1387, 796] # show data in view cone0Display = Show(cone0, renderView0) # trace defaults for the display properties. cone0Display.ColorArrayName = [None, ''] # reset view to fit data renderView0.ResetCamera() # current camera placement for renderView0 renderView0.CameraPosition = [0.0, 0.0, 3.2036135254332487] renderView0.CameraParallelScale = 0.8291561935301535 # save screenshot SaveScreenshot('/tmp/sample.png', magnification=1, quality=100, view=renderView0) WriteAnimation('/tmp/movie.png', Magnification=1, FrameRate=15.0, Compression=True) |
(0033059) Utkarsh Ayachit (administrator) 2014-07-22 08:32 |
--------------------------------------------- Topics merged into master: 0014874_fix_scalar_opacity_unit_distance 14834_fix_representation_update dashboard-warnings-20140721 refactor_python_tracing_2 |
(0033117) Alan Scott (manager) 2014-07-28 20:05 |
Tested master, Linux, remote server. |
2009-08-14 17:37 | Alan Scott | New Issue | |
2009-08-17 15:42 | Utkarsh Ayachit | Status | backlog => tabled |
2009-08-17 15:42 | Utkarsh Ayachit | Assigned To | => Pat Marion |
2009-08-17 15:42 | Utkarsh Ayachit | Priority | normal => urgent |
2009-09-01 11:30 | Pat Marion | Note Added: 0017278 | |
2009-09-01 11:30 | Pat Marion | Assigned To | Pat Marion => Alan Scott |
2009-09-01 11:30 | Pat Marion | Status | tabled => @20@ |
2009-09-01 16:34 | Alan Scott | Note Added: 0017288 | |
2009-09-01 16:34 | Alan Scott | Assigned To | Alan Scott => Pat Marion |
2009-09-01 16:34 | Alan Scott | Status | @20@ => tabled |
2009-09-01 20:58 | Berk Geveci | Note Added: 0017291 | |
2009-09-01 20:58 | Berk Geveci | Target Version | 3.6.2 => 3.8 |
2010-01-19 14:05 | Alan Scott | Relationship added | has duplicate 0009701 |
2010-02-01 14:28 | Utkarsh Ayachit | Priority | urgent => immediate |
2010-03-17 10:30 | Utkarsh Ayachit | Note Added: 0019935 | |
2010-03-17 10:30 | Utkarsh Ayachit | Priority | immediate => normal |
2010-03-17 10:30 | Utkarsh Ayachit | Target Version | 3.8 => 4.0 |
2012-10-24 17:20 | Alan Scott | Note Added: 0029506 | |
2012-10-24 17:20 | Alan Scott | Status | expired => backlog |
2012-10-24 17:20 | Alan Scott | Resolution | open => reopened |
2014-07-04 21:48 | Utkarsh Ayachit | Assigned To | Pat Marion => Utkarsh Ayachit |
2014-07-04 21:48 | Utkarsh Ayachit | Tag Attached: PythonTrace | |
2014-07-09 21:34 | Utkarsh Ayachit | Note Added: 0032999 | |
2014-07-18 21:00 | Utkarsh Ayachit | Topic Name | => refactor_python_tracing_2 |
2014-07-18 21:00 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-18 21:00 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-07-18 21:00 | Utkarsh Ayachit | Resolution | reopened => fixed |
2014-07-22 08:32 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-07-22 08:32 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-22 08:32 | Utkarsh Ayachit | Note Added: 0033059 | |
2014-07-28 20:05 | Alan Scott | Note Added: 0033117 | |
2014-07-28 20:05 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
