0009415 | ParaView | Bug | public | 2009-08-14 05:07 | 2010-01-21 19:29 | ||||
Reporter | Sven Buijssen | ||||||||
Product Version | 3.6 | ||||||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0009415: Toolbar Current Time Controls has max of 99 on load state event | ||||||||
Description | Load a file series consisting of more than 99 files into ParaView, save state, end paraview. Fire up ParaView again, load the same state file. You will notice that the Time object in the Information tab of the Object Inspector correctly lists all files of the series. The same holds for the Data Arrays object, it states the number of the last file under "current data time step:". The grayed out number in the Current Time Controls toolbar is correct, too. But the text box next to it displays 99 and does not allow a bigger number to be entered. Neither does the spinner next to the text box. Happens for latest release (ParaView 3.6.1) and top of cvs build. | ||||||||
Additional Information | You surely know how to quickly create a large file series, but to make it easier here's a bash one-liner for cut-and-paste: cd ParaViewData/Data/FileSeries; for i in `seq -f "%04g" 1 1200 `; do ln -s blow15.vtk blow_time${i}.vtk; done | ||||||||
Attached Files | 0001-BUG-Fixed-BUG-9415.-Animation-time-spin-box-s-range-.patch [^] (947 bytes) 2009-12-03 04:11 [Show Content] | ||||||||
(0018615) Benjamin Schindler (reporter) 2009-11-30 05:05 |
I can confirm this bug. I have a 400 timestep dataset and loading a state with timevalue above 99 makes paraview move to timestep 99. The animation view can still be used to select the timestep though I don't think this bug should be classified as minor. Also, this bug is the same bug as the one I filled half an year ago (0008717) which was errornously classified as a duplicate (The other bug is relevant, but does not cover the entire issue) |
(0018633) Utkarsh Ayachit (administrator) 2009-12-01 17:28 |
Animation time spin box's range wasn't getting updated during state loading. Fixed that. |
(0018673) Alan Scott (manager) 2009-12-02 20:13 |
Utkarsh, I used the wonderful bash script below, and made about 1000 and something linked files. I then opened blow, and stepped to the 1000th time step. The time in the tine control is not quite wide enough - it is truncating part of the 0. How about if we widen this up enough to cleanly handle up to 10000 time steps? If you don't agree, just resolve or close this bug again - I can live with it is it is. Alan |
(0018684) Benjamin Schindler (reporter) 2009-12-03 03:14 |
Another request from my side - since I don't have a checkout here, would you mind posting/mailing me a diff so I can apply it on my local sources? This bugfix is extremely important for me Thanks! |
(0018685) Sven Buijssen (reporter) 2009-12-03 04:10 |
Thanks for directing attention to this one, bschindler. To return the favor please find attached the patch requested. |
(0018686) Benjamin Schindler (reporter) 2009-12-03 04:49 |
Thank you for the patch! That was quick! I applied it and it fixed the issue on my side. Now remaining is the issue wascott described with >1000 timesteps, but may be this should go in a separate bug? |
(0019203) Utkarsh Ayachit (administrator) 2010-01-19 16:47 |
Made the widget 5 digit wide. |
(0019258) Alan Scott (manager) 2010-01-21 19:29 |
Tested local server, XP, trunk. |
2009-08-14 05:07 | Sven Buijssen | New Issue | |
2009-11-30 05:05 | Benjamin Schindler | Note Added: 0018615 | |
2009-12-01 17:28 | Utkarsh Ayachit | Note Added: 0018633 | |
2009-12-01 17:28 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-12-01 17:28 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2009-12-01 17:28 | Utkarsh Ayachit | Resolution | open => fixed |
2009-12-01 17:28 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-02 20:13 | Alan Scott | Note Added: 0018673 | |
2009-12-02 20:13 | Alan Scott | Status | @80@ => @20@ |
2009-12-02 20:13 | Alan Scott | Resolution | fixed => reopened |
2009-12-03 03:14 | Benjamin Schindler | Note Added: 0018684 | |
2009-12-03 04:10 | Sven Buijssen | Note Added: 0018685 | |
2009-12-03 04:11 | Sven Buijssen | File Added: 0001-BUG-Fixed-BUG-9415.-Animation-time-spin-box-s-range-.patch | |
2009-12-03 04:49 | Benjamin Schindler | Note Added: 0018686 | |
2010-01-19 16:47 | Utkarsh Ayachit | Note Added: 0019203 | |
2010-01-19 16:47 | Utkarsh Ayachit | Status | @20@ => @80@ |
2010-01-19 16:47 | Utkarsh Ayachit | Resolution | reopened => fixed |
2010-01-21 19:29 | Alan Scott | Note Added: 0019258 | |
2010-01-21 19:29 | Alan Scott | Status | @80@ => closed |
