0009365 | VTK | (No Category) | public | 2009-08-05 09:20 | 2016-08-12 09:55 | ||||
Reporter | Sergey Anikin | ||||||||
Summary | 0009365: Unnecessary glFlush() call in vtkOpenGLFreeTypeTextMapper::RenderOverlay() | ||||||||
Description | In VTK 5.4.2 and older versions there is a strange glFlush() call in vtkOpenGLFreeTypeTextMapper::RenderOverlay(). Even if it leads to no visible consequences on most "native" Linux X servers (neither locally nor through a remote connection), on some Win32 X servers like X-Win32 or Exceed it results in frame buffer swapping, and everything drawn after the first text label goes immediately to the active frame buffer and appears on the screen. I have tried to comment glFlush() call (most likely, it remains there since some debugging). This resolves my problem, thus I attach the corrected source file for validation and testing. | ||||||||
Attached Files | vtkOpenGLFreeTypeTextMapper.tar.gz [^] (3,988 bytes) 2009-08-05 09:20 | ||||||||
(0018280) Sean McBride (developer) 2009-10-29 14:12 |
I tried this change on my working copy and 1) no new test failures were introduced 2) it does not cause any problems in my app, including where I use vtk to draw text. flushes are expensive, so if this really isn't needed, that'd be nice. Assigning to François because I know he knows about ogl&vtk. :) |
(0037093) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-08-05 09:20 | Sergey Anikin | New Issue | |
2009-08-05 09:20 | Sergey Anikin | File Added: vtkOpenGLFreeTypeTextMapper.tar.gz | |
2009-10-29 14:12 | Sean McBride | Note Added: 0018280 | |
2009-10-29 14:12 | Sean McBride | Status | backlog => tabled |
2009-10-29 14:12 | Sean McBride | Assigned To | => François Bertel |
2010-09-07 13:44 | François Bertel | Assigned To | François Bertel => |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037093 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
