0009326ParaViewBugpublic2009-07-28 19:422016-08-12 09:57
ReporterKen Moreland
Assigned ToDavid Partyka
PrioritylowSeverityminorReproducibilityhave not tried
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Target VersionNeedsVerificationFixed in Version
Summary0009326: Odd add keyframe behavior
DescriptionThe behavior when you add a keyframe in the Animation Keyframes dialog box has changed a bit for the worse between PV 3.4 and 3.6. Before, when you added a track, then opened the keyframe editor for that track and click the "New" button to add a keyframe, it would create one with the time and value in between the two existing values. Now it basically duplicates the first keyframe. To replicate:
1. Create a Sphere source.
2. Open the Animation View.
3. Add a track for Start Theta.
3. Double click the new track.
4. Click "New".
The new track is also at time 0 and its value is 0. Before the added track was at time 0.5 and had value 180.
It looks like this change comes from some changes in how keyframes are added. It looks like the New keyframe now adds a keyframe before the selected keyframe, and if none is selected it adds it "before" the first one. That seems like odd default behavior. Perhaps a special case it should add it after the first one and before the rest.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
related to 0016022closedKitware Robot More powerful animation track
-  Notes
(0037670)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
- Issue History
2009-07-28 19:42 Ken Moreland New Issue
2011-02-04 13:59 David Partyka Assigned To => David Partyka
2011-02-04 13:59 David Partyka Status backlog => tabled
2011-02-04 13:59 David Partyka Target Version 3.8 => NeedsVerification
2013-01-08 21:31 Alan Scott Project => Sandia
2013-01-08 21:31 Alan Scott Type => incorrect functionality
2016-03-09 13:30 Alan Scott Relationship added related to 0016022
2016-08-12 09:57 Kitware Robot Note Added: 0037670
2016-08-12 09:57 Kitware Robot Status backlog => closed
2016-08-12 09:57 Kitware Robot Resolution open => moved
Powered by Mantis Bugtracker
