0009313 | ParaView | Bug | public | 2009-07-24 15:59 | 2014-01-21 13:08 | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Product Version | NeedsVerification | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0009313: Odd dockable sizing when swapping views. | ||||||||
Description | In the latest binary download (3.6.1) on Mac, I discovered some strange behavior with the size of the dockable windows (specifically the pipeline browser and object inspector). When I have two views next to each other horizontally and I swap them, both views become super thin and the dockable windows take up most of the main window. To replicate this, do the following. 1. Load up ParaView with default everything. (Disable registry is fine.) 2. Split the view horizontally. 3. Grab the toolbar of one view and drag it to the other view to swap them. When the views are swapped, you will see that everything gets resized rather badly when in fact nothing should be resized. | ||||||||
Project | Sandia | ||||||||
(0032199) Utkarsh Ayachit (administrator) 2014-01-21 12:00 |
I wonder if this is still an issue. Please reopen if that's the case. |
(0032201) Ken Moreland (manager) 2014-01-21 13:08 |
Looks like the problem is fixed, although as I was testing it, I found another bug (0014530). |
2009-07-24 15:59 | Ken Moreland | New Issue | |
2011-02-04 13:51 | David Partyka | Assigned To | => David Partyka |
2011-02-04 13:51 | David Partyka | Status | backlog => tabled |
2011-02-04 13:51 | David Partyka | Product Version | => NeedsVerification |
2013-01-08 21:31 | Alan Scott | Project | => Sandia |
2013-01-08 21:31 | Alan Scott | Type | => incorrect functionality |
2013-02-06 18:33 | Utkarsh Ayachit | Assigned To | David Partyka => Nikhil Shetty |
2013-06-05 16:01 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2014-01-21 12:00 | Utkarsh Ayachit | Note Added: 0032199 | |
2014-01-21 12:00 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-01-21 12:00 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2014-01-21 12:00 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-01-21 12:00 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-01-21 12:00 | Utkarsh Ayachit | Fixed in Version | => 4.1 |
2014-01-21 13:08 | Ken Moreland | Note Added: 0032201 | |
2014-01-21 13:08 | Ken Moreland | Status | customer review => closed |
