0000093 | VTK | (No Category) | public | 2003-07-24 10:47 | 2011-01-13 17:00 | ||||
Reporter | Will Schroeder | ||||||||
Assigned To | Mathieu Malaterre | ||||||||
Summary | 0000093: UnstructuredGrid::Locations array should be of type vtkIdTypeArray | ||||||||
Description | For very large data the use of vtkUnstructuredGrid::Locations (currently of type vtkIntArray) will fail. It should be of type vtkIdTypeArray. This will require changing several method signatures (used internally, hopefully not a lot of public usage). | ||||||||
(0000536) Mathieu Malaterre (developer) 2004-01-21 17:17 |
Modifications are done locally. Compilation done in 32bits and 64bits, all were successfull. |
(0000554) Mathieu Malaterre (developer) 2004-01-22 09:41 |
Done on 01/22 Checking in Common/vtkUnstructuredGrid.cxx; /cvsroot/VTK/VTK/Common/vtkUnstructuredGrid.cxx,v <-- vtkUnstructuredGrid.cxx new revision: 1.118; previous revision: 1.117 done Checking in Common/vtkUnstructuredGrid.h; /cvsroot/VTK/VTK/Common/vtkUnstructuredGrid.h,v <-- vtkUnstructuredGrid.h new revision: 1.97; previous revision: 1.96 done Checking in Graphics/vtkClipDataSet.cxx; /cvsroot/VTK/VTK/Graphics/vtkClipDataSet.cxx,v <-- vtkClipDataSet.cxx new revision: 1.33; previous revision: 1.32 done Checking in Graphics/vtkClipVolume.cxx; /cvsroot/VTK/VTK/Graphics/vtkClipVolume.cxx,v <-- vtkClipVolume.cxx new revision: 1.65; previous revision: 1.64 done Checking in Graphics/vtkClipVolume.h; /cvsroot/VTK/VTK/Graphics/vtkClipVolume.h,v <-- vtkClipVolume.h new revision: 1.40; previous revision: 1.39 done Checking in IO/vtkXMLPUnstructuredGridReader.cxx; /cvsroot/VTK/VTK/IO/vtkXMLPUnstructuredGridReader.cxx,v <-- vtkXMLPUnstructuredGridReader.cxx new revision: 1.6; previous revision: 1.5 done Checking in IO/vtkXMLUnstructuredGridReader.cxx; /cvsroot/VTK/VTK/IO/vtkXMLUnstructuredGridReader.cxx,v <-- vtkXMLUnstructuredGridReader.cxx new revision: 1.7; previous revision: 1.6 done |
2010-11-29 17:59 | Mathieu Malaterre | Source_changeset_attached | => VTK master e6504300 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
