0009299ParaViewBugpublic2009-07-22 12:282016-08-12 09:57
ReporterDavid Doria
Assigned ToRobert Maynard
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0009299: List of servers does not save immediately when a server is added
DescriptionIf you create a new server and try to connect to it, if the connection fails and you kill the process and restart paraview, the server you just added is not in the list of servers and needs to be recreated. I think the list should be saved right away when the server is added.
TagsNo tags attached.
Project
Topic Name
Type
related to 0009297closedRobert Maynard "edit server" fields
-  Notes
(0025333)
Glenn Faken (reporter)
2011-02-08 13:07
I will take a look at this and see if I can reproduce it.
(0037667)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
- Issue History
2009-07-22 12:28 David Doria New Issue
2011-02-04 13:47 David Partyka Assigned To => Robert Maynard
2011-02-04 13:47 David Partyka Status backlog => tabled
2011-02-04 15:11 Robert Maynard Relationship added related to 0009297
2011-02-08 13:07 Glenn Faken Note Added: 0025333
2016-08-12 09:57 Kitware Robot Note Added: 0037667
2016-08-12 09:57 Kitware Robot Status backlog => closed
2016-08-12 09:57 Kitware Robot Resolution open => moved
Powered by Mantis Bugtracker
