0009283 | VTK | (No Category) | public | 2009-07-17 18:58 | 2016-08-12 09:55 | ||||
Reporter | dbarbier | ||||||||
Summary | 0009283: VTK segfaults when combining vtkTreeMapView and vtkSelectionLink | ||||||||
Description | Hi, Examples/Infovis/Java/TreeViews.java works fine with VTK 5.2, but segfaults with VTK 5.4. This can be reproduced in C++ with simple changes in Examples/Infovis/Cxx/MultiView.cxx: sed -i -e 's/vtkTreeLayoutView/vtkTreeMapView/g' -e 's/view2->SetLabel/view2->SetAreaLabel/g' MultiView.cxx Here is output before segfault occurs: ERROR: In /home/barbier/Projects/VTK-5-4/Graphics/vtkConvertSelection.cxx, line 805 vtkConvertSelection (0x8c8e90): Output selection array does not exist in input dataset. ERROR: In /home/barbier/Projects/VTK-5-4/Filtering/vtkExecutive.cxx, line 757 vtkStreamingDemandDrivenPipeline (0x8c0800): Algorithm vtkConvertSelection(0x8c8e90) returned failure for request: vtkInformation (0x8c4e10) Debug: Off Modified Time: 59314 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 | ||||||||
(0037090) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2009-07-17 18:58 | dbarbier | New Issue | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037090 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
