0009280 | ParaView | Bug | public | 2009-07-16 12:54 | 2009-08-05 19:48 | ||||
Target Version | 3.6.2 | Fixed in Version | 3.6.2 | ||||||
Summary | 0009280: Probe-based filters disabled for pipeline sources with multiple outputs | ||||||||
Description | There is some incorrect logic in the input domains that is disabling all of the probe-based filters (such as probe location and plot over line) for any pipeline source with multiple outputs. To replicate: 1. Load the file VTKLargeData/Data/SLAC/pic-example/mesh.ncdf. 2. Try to use any probe-based filter. They will be grayed out. This behavior also happens for any filter that has multiple outputs. Try it on, for example, the particle pathlines filter. | ||||||||
(0017038) Utkarsh Ayachit (administrator) 2009-07-31 11:48 |
Obsolete vtkSMNumberOfPartsDomain was used for all the probe filters which restricted the input to being a source with single output port. In olden days, number of parts corresponded to number of blocks in a composite dataset and hence it made sense for older versions of these filters. Not any more. So removing this domain all together. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- Servers/ServerManager/CMakeLists.txt new revision: 1.255; previous revision: 1.254 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMExtractDocumentation.cxx,v <-- Servers/ServerManager/vtkSMExtractDocumentation.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMNumberOfPartsDomain.cxx,v <-- Servers/ServerManager/vtkSMNumberOfPartsDomain.cxx new revision: delete; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMNumberOfPartsDomain.h,v <-- Servers/ServerManager/vtkSMNumberOfPartsDomain.h new revision: delete; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.361; previous revision: 1.360 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/Cxx/ServersServerManagerPrintSelf.cxx,v <-- Servers/ServerManager/Testing/Cxx/ServersServerManagerPrintSelf.cxx new revision: 1.29; previous revision: 1.28 3.6 Branch-------- (Only committing minimal change required which addresses this bug) /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.345.2.5; previous revision: 1.345.2.4 |
(0017072) Alan Scott (manager) 2009-08-05 19:48 |
I believe this one is fixed. Works for probe point. I was able to bring up particle pathlines, but it put out lots of failure prints. Since error prints are not part of this bug (and I probably don't know how to run the filter anyway), I am closing this bug. |
2009-07-16 12:54 | Ken Moreland | New Issue | |
2009-07-16 12:54 | Ken Moreland | Status | backlog => tabled |
2009-07-16 12:54 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2009-07-31 11:48 | Utkarsh Ayachit | Note Added: 0017038 | |
2009-07-31 11:48 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-07-31 11:48 | Utkarsh Ayachit | Fixed in Version | => 3.6.2 |
2009-07-31 11:48 | Utkarsh Ayachit | Resolution | open => fixed |
2009-08-05 19:48 | Alan Scott | Note Added: 0017072 | |
2009-08-05 19:48 | Alan Scott | Status | @80@ => closed |
