0009270 | ParaView | Bug | public | 2009-07-13 22:58 | 2009-07-22 17:20 | ||||
Assigned To | Julien Finet | ||||||||
Target Version | 3.6.2 | Fixed in Version | 3.6.2 | ||||||
Summary | 0009270: Directory names disappear | ||||||||
Description | Some directory name patterns hide directories. This is not acceptable. I replicated this with 4.6.0, XP client, 2 servers on Linux. Make the following directories, with nothing in them, then try to move into each of these directories with ParaView Open: ab_123kg_45 ab_123kg_56 ab_123kg_67 You will only see one of these three directories. The workaround is to add a -dir to the end of each of the directory names. This must be fixed for 3.6.2, unless it is quite hard. | ||||||||
(0016895) Julien Finet (developer) 2009-07-17 20:10 |
We now make sure that files named aa_123_bb_01 and aa_123_bb_02 are correctly processed. The group should be indexed on 01/02 instead of 123. File modified: vtkPVFileInformation.cxx:1.35 |
(0016941) Alan Scott (manager) 2009-07-22 16:49 |
Fixed. Tested local server, Linux trunk. |
(0016944) Utkarsh Ayachit (administrator) 2009-07-22 17:19 |
Committed to 3.6 branch. Patch title (first comment line): BUG: make sure that files named aa_123_bb_01 and aa_123_bb_02 are correctly processed. the group should be indexed on 01/02 instead of 123. BugID:9181 Autocommit cvs commit -F .msg 'Servers/Common/vtkPVFileInformation.cxx' Committer: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVFileInformation.cxx,v <-- Servers/Common/vtkPVFileInformation.cxx new revision: 1.32.2.1; previous revision: 1.32 Committed successfully to CVS |
2009-07-13 22:58 | Alan Scott | New Issue | |
2009-07-15 11:29 | Utkarsh Ayachit | Status | backlog => tabled |
2009-07-15 11:29 | Utkarsh Ayachit | Assigned To | => Julien Finet |
2009-07-17 20:10 | Julien Finet | Note Added: 0016895 | |
2009-07-17 20:10 | Julien Finet | Status | tabled => @80@ |
2009-07-17 20:10 | Julien Finet | Resolution | open => fixed |
2009-07-22 16:49 | Alan Scott | Note Added: 0016941 | |
2009-07-22 16:49 | Alan Scott | Status | @80@ => closed |
2009-07-22 17:19 | Utkarsh Ayachit | Note Added: 0016944 | |
2009-07-22 17:20 | Utkarsh Ayachit | Fixed in Version | => 3.6.2 |
2009-07-22 17:20 | Utkarsh Ayachit | Target Version | => 3.6.2 |
