0009127 | ParaView | Bug | public | 2009-06-09 21:33 | 2013-10-28 19:16 | ||||
Assigned To | Alan Scott | ||||||||
Summary | 0009127: Specify Each of the Axis Labels doesn't work at all | ||||||||
Description | Local server, XP, trunk (and I suspect 3.6.0) Open disk_out_ref.exo, all variables on, apply. Plot over line, apply. Edit view options (nit - this should be the same as the name on the window that comes up, which is Line Chart Options). Bottom Axis/ Layout/ Specify Each of the Axis Labels. New Label - 20.0 New Label - 30.0 Apply, then OK. Bug - Nothing happens to the bottom axis. | ||||||||
(0016687) Ken Moreland (manager) 2009-06-10 09:32 |
Comment on the nit: We can't change the name of the menu item to "Line Chart Options" because that menu item applies to the options to whatever the current view is, regardless of its type. I suppose we could change it based on the current view, but that could get confusing. I would much rather change the name of the dialog. Perhaps we should change the dialog title from "<view type> Options" to "View Options (<view type>)". So in this instance the dialog would be "View Options (Line Chart)". |
(0016698) Alan Scott (manager) 2009-06-10 16:12 |
I like Ken's suggestion! |
(0017197) Alan Scott (manager) 2009-08-24 16:47 |
Please implement this for 3.6.2 if it is reasonably easy. Otherwise, defer to 3.8.0. |
(0017256) Utkarsh Ayachit (administrator) 2009-08-31 16:11 |
The new charts don't support this functionality. Consequently for 3.6 branch we had disabled the GUI so that the option to specify labels is not available at all. |
(0017258) Utkarsh Ayachit (administrator) 2009-08-31 16:17 |
Partial fix for BUG 0009127. Changed the options dialog titles to "View Settings (Bar Chart)" etc. /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveChartOptions.cxx,v <-- Qt/Components/pqActiveChartOptions.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveRenderViewOptions.cxx,v <-- Qt/Components/pqActiveRenderViewOptions.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqBarChartOptionsWidget.ui,v <-- Qt/Components/Resources/UI/pqBarChartOptionsWidget.ui new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqLineChartOptionsWidget.ui,v <-- Qt/Components/Resources/UI/pqLineChartOptionsWidget.ui new revision: 1.2; previous revision: 1.1 Pending 3.6 commit. |
(0031750) Alan Scott (manager) 2013-10-28 19:16 |
This is fixed in current master. |
2009-06-09 21:33 | Alan Scott | New Issue | |
2009-06-10 09:32 | Ken Moreland | Note Added: 0016687 | |
2009-06-10 16:12 | Alan Scott | Note Added: 0016698 | |
2009-08-24 16:16 | Alan Scott | Target Version | => 3.6.2 |
2009-08-24 16:47 | Alan Scott | Note Added: 0017197 | |
2009-08-31 16:11 | Utkarsh Ayachit | Note Added: 0017256 | |
2009-08-31 16:11 | Utkarsh Ayachit | Target Version | 3.6.2 => 3.8 |
2009-08-31 16:17 | Utkarsh Ayachit | Note Added: 0017258 | |
2013-10-28 19:16 | Alan Scott | Note Added: 0031750 | |
2013-10-28 19:16 | Alan Scott | Status | expired => closed |
2013-10-28 19:16 | Alan Scott | Assigned To | => Alan Scott |
2013-10-28 19:16 | Alan Scott | Resolution | open => fixed |
