0009082 | ParaView | Bug | public | 2009-05-29 11:40 | 2011-09-01 13:31 | ||||
Assigned To | Julien Finet | ||||||||
Target Version | 3.8 | Fixed in Version | 3.12 | ||||||
Summary | 0009082: Plot Edges by Plane Intersect does not actually plot field data | ||||||||
Description | When you use the plot edges by plane intersect, it creates poly data at the intersection of plane and surface, orders the lines, and pops up a plot. However, the field data is not extracted in the plot. Because there are no data series, the plot window is empty. To replicate: 1. Create a wavelet source. Apply. 2. Add the Plot Edges by Plane Intersect filter. Apply. A plot view is created, but it is empty. This is because the RTData field from the wavelet is not part of the plot data and there are really no valid series to plot. | ||||||||
(0016593) Julien Finet (developer) 2009-05-29 14:15 |
The output polyData didn't preserve the vtkDataArrays of the input polyData vtkPointData. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPlotEdges.cxx,v <-- vtkPlotEdges.cxx new revision: 1.6; previous revision: 1.5 |
(0016637) Utkarsh Ayachit (administrator) 2009-06-04 15:56 |
The filter's now called "Plot On Intersection Curves" |
(0016680) Alan Scott (manager) 2009-06-09 20:34 |
Tested remote server. Since I don't know what the plot should look like, I don't know how to tell if it is correct or not. Assuming that it is correct. |
2009-05-29 11:40 | Ken Moreland | New Issue | |
2009-05-29 11:40 | Ken Moreland | Status | backlog => tabled |
2009-05-29 11:40 | Ken Moreland | Assigned To | => Julien Finet |
2009-05-29 14:15 | Julien Finet | Note Added: 0016593 | |
2009-05-29 14:15 | Julien Finet | Status | tabled => @80@ |
2009-05-29 14:15 | Julien Finet | Fixed in Version | => Development |
2009-05-29 14:15 | Julien Finet | Resolution | open => fixed |
2009-06-04 15:56 | Utkarsh Ayachit | Note Added: 0016637 | |
2009-06-09 20:34 | Alan Scott | Note Added: 0016680 | |
2009-06-09 20:34 | Alan Scott | Status | @80@ => closed |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
